Project Leone PHASE 2 ‘EJ TIME’
hehe Dave u think YOU have stuff taking up your space, come checkout my yard!
Subaru graveyard haha.
Ok, the Leone now has
- EJ22 fitted with EA82 flywheel modded to suit EJ
- 12MM Alloy Adaptor Plate / Spacer to space and blot EA gearbox to EJ motor
- EA82 FTAWD Gearbox
- EA82 MPFI tank and pump
Now to fit EJ22 loom and ecu (that Dave has cut down and tagged very well and is a work of art), install high pressure fuel lines.
Going to get stuck into her tonight!
Hunter S. Thompson
Hunter S. Thompson
An update
Both brendan and alex car have now got running engines in them..all thats left is a clean up and the radiator's to be further modified slightly and the convserions will be complete
:D:D
dave
dave
Big thanks going out to Andrew for letting us use his Wacky Workshop..
Also to Subarino Dave for all his hard wiring and electrical skillz
Young Matt and David also for there help with various parts, and also Alex for all my emotional and sexual support
Thanks Fellas
Thanks Fellas
Hunter S. Thompson
Hunter S. Thompson
Hunter S. Thompson
Hunter S. Thompson
bhahaha! love that photo
Hunter S. Thompson
Hunter S. Thompson
Leone update, she went for a quick test run last night when we locked in the centre diff and ran her as rwd.. The ftawd box felt great and I cant wait to see how she will be with the front shafts in running awd..
Prolly a good idea I remove a rear cv shaft tho as the locker might not agree with the box?
Hunter S. Thompson
Hunter S. Thompson
The locked rear diff should be fine with the EA82 AWD gearbox, they don't have a centre LSD to bugger up. I beleive its just an open centre.
ahh troo didnt think of that.. and when lock the centre diff it dosent matter because should be in the boggy stuff :P
i put one of the front awd cv's in now.. just have to get the other out of the hub and chuck it in.. and i can test the awd out..
Hunter S. Thompson
Hunter S. Thompson
I agree... however... bare in mind the rare-ity of your new gear box... running a welded diff wont be good for it. It will work fine with it in there... but I wouldn't want to be putting the box under any extra stress if i was you.
Dave
Dave
yeh troo, might be time to seek out an lsd...
Hunter S. Thompson
Hunter S. Thompson
lucky i checked my tailshaft bolts :P didnt know ya finger tighted them :Psubi wrote:yay conversion is complete. call me up for the test run fellas!
Hunter S. Thompson
Hunter S. Thompson
hhaah, tis all good..
Hunter S. Thompson
Hunter S. Thompson
I would recomend personally checking all the bolts... both Alex and Muffin...
I recall Alex running and starting the car before without the engine/gear box bolts done up tight... could have ended badly if no one had of noticed.
Dave
Dave
- waggaclint
