CHEMISTS ! uric salt bio film clean up :(
thatsgoodsquishy
Post by thatsgoodsquishy » Tue Sep 28, 2010 8:45 pm
When i used it i just added maybe 300 or 400ml to the bowl water before going to work or last thing at night. No scrubbing, no draining, zero effort. Went through 2 or 3 bottles but home brand vinegar is cheap as chips ;)
Ben
Current: MY 07 Outback 3L
Previous: 02 B4 Manual
Previous: 95 Liberty Wagon 'Rallye'
Previous: 85 L series Touring Wagon, Auto to Manual conversion
Post by Gannon » Sat Oct 02, 2010 7:38 am
Half a bottle of vinegar and let sit for 24 hours, bit of scrubbing and 90% of it flaked off.
Second half a bottle and another 24 hours later, a light scrub with the brush and it all gone.
I nominate Jono as the king of cleaning johns
Cliff R
Post by Cliff R » Sat Oct 02, 2010 12:11 pm
We have the same crusty toilet bowl issue too. I have acquired some Chemical cleaner (dont know the name) and was advised to let it sit in the bowl for a few hours and all would be sweet (so to speak). Plan B was to empty the bowl and fill it with Coke. This stuff will clean anything so imagine what it would do to your stomach. Anyway seems vinegar is the go so we may try that first.
Open Slather in a Subaru forum to clean a toilet. Gotta love that !!
Post by steptoe » Sat Oct 02, 2010 2:23 pm
Thanks Gannon , but if you read through the posts you will find the crown goes to TOONGA
* Note to PR dept, we will need a photo of King TOONGA on his throne when all this gets out !! :)
$1.09 for two litres of vinegar , must be a bit cheaper than Coke. Maybe you should try Coke for same 24 hours and report back
Had to be here in open slather. was not gonna wait for mythbusters to do it
Post by Gannon » Sat Oct 02, 2010 3:33 pm
I have a 2nd toilet that also needs doing, just have to wait for the cistern block to be used up.
I'll give the cheap home brand Cola a go
seagull
Post by seagull » Mon Nov 01, 2010 12:06 am
Clear Bore
Post by steptoe » Mon Nov 01, 2010 11:37 am
Clear Bore ? Can you expand on that a bit more please?
Post by TOONGA » Mon Nov 01, 2010 1:39 pm
http://www.clearbore.com.au/
CLEARBORE - The leading water bore and water pump cleaner.
The biofilm and encrustations in water bores, pumps and irrigation equipment caused by dissolved iron and Iron-related bacteria are simply dissolved away by Clearbore water bore cleaner. Clearbore is a safe, biodegradable and effective product for cleaning water bores and water pumps.
X-Fe and X-Fe Forte are revolutionary bore water stain removers.
The stain caused by precipitated iron can easily be removed using these products.
Clearbore Pty Ltd products are safe, simple to use and completely biodegradable. They contain no chlorine, hydrochloric acid, copper or cupric solutions.
Clearbore Pty Ltd products are marketed throughout Australia, New Zealand, United Kingdom and Papua New Guinea by a network of appointed dealers.
seems like good stuff for removing stains
Subyroo
Post by Subyroo » Tue Nov 02, 2010 8:23 pm
TOONGA wrote:http://www.clearbore.com.au/
I wonder if it would clean ya bore out if you were constipated?
:twisted: :twisted: :twisted: :twisted:
P.S. The above comment is a joke DO NOT DRINK CLEARBORE UNDER ANY CIRCUMSTANCE.
Peter
Post by steptoe » Tue Nov 02, 2010 10:24 pm
drink it ? I thought you were suggesting an enemaic approach :)
Subyroo
Post by Subyroo » Wed Nov 03, 2010 11:52 am
steptoe wrote:drink it ? I thought you were suggesting an enemaic approach :)
Whatever tickles ya fancy!
:-D :-D :-D :-D
Peter
