Adjustable Height Rear Struts..... Air ???
So when I load all my 5hit in my car for trippin away... fridge... recovery... fuel water... etc etc..... the rear end sits right down. I've got some decent Kings in there and a tidy bodlift.... but I was thinking maybe I could get some adjustable air shocks??? I used to use them years ago on old holdens.
I just want to be able to get the arse back off the ground when loaded... and... retain as much rear articulation as possible..
Anyone setup any Suby with anything like this???
Here's the car if you want a squiz......
showthread.php?p=91856#post91856
You could find some electronically controlled air struts from an old Lib but everyone says they are absolute poo anyway. Should be lots available for cheap due to people replacing them with normal struts.
I'm trying to keep it as simple as possible. Don't want 5hit goin pear shaped somewhere north of Broome......AndrewT wrote:You could find some electronically controlled air struts from an old Lib but everyone says they are absolute poo anyway. Should be lots available for cheap due to people replacing them with normal struts.
'00 Forester - H6 - ViPEC V88 - Safari Snorkel
Scorpion Low Range - SubaXtreme Front/Rear Bars - Spring/Strut/Body Lift
nuvi 760 - OziExplorer CE on iPaq212 - Dual Batts - icom ic-400 (comms)
ABS cut out switch - Fan cut out switch
BFG 215/75 ATs
An urge to fly...
BFG 215/75 ATs
An urge to fly...
