front tyre scrubbing......
- brumbybear
hi guys i just picked up my brumby the other day and ive noticed if i turn the wheels to the right the right one scrubs but not the left.... and if i take off a bit quick the right tyre scrubs again even in a straight line..... grrr... i wanna lift it but i cant find any lift kits and the apparently the bloke on here that does em his mum is crook.... so if i can figure out whats going on i might be able to sort it out before i lift it...
cheers brumbybear
cheers brumbybear
Im looking for a cheap second hand 2-4" lift kit for my brumby... if u have one pm me plz
- brumbybear
- TOONGA
more than likely its those horrible plastic mudflaps on the front pull em off and see if there is any difference
otherwise its the plastic surround under the guard or as I call them the the mud collectors/ rust creators
two points to consider the bottom of the front of the guard and the bottom of the back of the guard where it bolts on to the body
in the red areas on the picture below is where I have had the most rubbing
- brumbybear
Have you tried Crossbred Performance for a lift kit. Jeff sells them . If you look in the classified section, you should see some there for sale from Crossbred Performance.brumbybear wrote:.. i wanna lift it but i cant find any lift kits and the apparently the bloke on here that does em his mum is crook....
cheers brumbybear
rtcb65
Redneck Rick.
Redneck Rick.
- brumbybear
