front tyre scrubbing......
brumbybear
Post by brumbybear » Fri Feb 05, 2010 10:42 am
hi guys i just picked up my brumby the other day and ive noticed if i turn the wheels to the right the right one scrubs but not the left.... and if i take off a bit quick the right tyre scrubs again even in a straight line..... grrr... i wanna lift it but i cant find any lift kits and the apparently the bloke on here that does em his mum is crook.... so if i can figure out whats going on i might be able to sort it out before i lift it...
cheers brumbybear
Im looking for a cheap second hand 2-4" lift kit for my brumby... if u have one pm me plz
Post by steptoe » Fri Feb 05, 2010 11:26 am
a front wheel alignment candidate, but that ain't worth it unless ball joints and tie rods and rack ends are in good order. Castor rod bushes, anything bent?
brumbybear
Post by brumbybear » Fri Feb 05, 2010 11:45 am
im getting under it this arvo and going to go over it all i reckon.. Mmmm i hope it isnt any thing too serious...
Post by TOONGA » Fri Feb 05, 2010 2:50 pm
more than likely its those horrible plastic mudflaps on the front pull em off and see if there is any difference
otherwise its the plastic surround under the guard or as I call them the the mud collectors/ rust creators
two points to consider the bottom of the front of the guard and the bottom of the back of the guard where it bolts on to the body
in the red areas on the picture below is where I have had the most rubbing
brumbybear
Post by brumbybear » Fri Feb 05, 2010 2:55 pm
thanx for that toonga ill check it out shortly when i get outside
rtcb65
Post by rtcb65 » Fri Feb 05, 2010 4:33 pm
brumbybear wrote:.. i wanna lift it but i cant find any lift kits and the apparently the bloke on here that does em his mum is crook....
cheers brumbybear
Have you tried Crossbred Performance for a lift kit. Jeff sells them . If you look in the classified section, you should see some there for sale from Crossbred Performance.
rtcb65
Redneck Rick.
brumbybear
Post by brumbybear » Tue Feb 09, 2010 2:28 pm
well i have pulled out the plastic inner guards on both sides and it still scrubs.... plenty of clearance inside guards..... could a wheel bearing or CV be the cause of the noise??
cheers brumbybear
