Suspensionlift
Suspensionlift
Where can I get the suspension lift from in Melbourne?
For a subaru Brat
For a subaru Brat
David, I'd be going for the body lift. These older subarus need the body lift to keep the CVs happy in the long term. If you go for a 2 inch suspension lift only you'll chew through CVs faster than you can think about.Wesvo wrote:The website has body lift kit,
I need the suspension 2"lift
Unless you've got the body lift blocks already it's not worth looking for the strut lift only. Even then this won't work on the rear as it's a torsion bar setup - there's a bolt in the centre of the setup that you can wind up or down to change the rear's stance. Some level it out, I like a bit of lift in mine... if I had one.
Thanks for the info, I need that body lift but also the suspension lift that's the problemEl_Freddo wrote:David, I'd be going for the body lift. These older subarus need the body lift to keep the CVs happy in the long term. If you go for a 2 inch suspension lift only you'll chew through CVs faster than you can think about.
Thanks Bennie
