Suspensionlift
Wesvo
Suspensionlift
Post by Wesvo » Wed Aug 29, 2012 5:31 pm
Where can I get the suspension lift from in Melbourne?
For a subaru Brat
stilson
Post by stilson » Wed Aug 29, 2012 5:55 pm
Try crossbread performance.
[url]http://www.*********performance.com/contact[/url]
MY08 SG9 XS LUX
********* performance sump and diff guards.
Post by TOONGA » Wed Aug 29, 2012 5:59 pm
without the "A" in it :)
Wesvo
Post by Wesvo » Wed Aug 29, 2012 5:59 pm
stilson wrote:Try crossbread performance.
Thanks stilson
Wesvo
Post by Wesvo » Wed Aug 29, 2012 6:01 pm
The website has body lift kit,
I need the suspension 2"lift
Thanks
David
Post by El_Freddo » Wed Aug 29, 2012 7:06 pm
Wesvo wrote:The website has body lift kit,
David, I'd be going for the body lift. These older subarus need the body lift to keep the CVs happy in the long term. If you go for a 2 inch suspension lift only you'll chew through CVs faster than you can think about.
Unless you've got the body lift blocks already it's not worth looking for the strut lift only. Even then this won't work on the rear as it's a torsion bar setup - there's a bolt in the centre of the setup that you can wind up or down to change the rear's stance. Some level it out, I like a bit of lift in mine... if I had one.
Wesvo
Post by Wesvo » Wed Aug 29, 2012 7:39 pm
El_Freddo wrote:David, I'd be going for the body lift. These older subarus need the body lift to keep the CVs happy in the long term. If you go for a 2 inch suspension lift only you'll chew through CVs faster than you can think about.
Thanks for the info, I need that body lift but also the suspension lift that's the problem
Thanks Bennie
Post by El_Freddo » Wed Aug 29, 2012 8:09 pm
Wesvo wrote:Thanks for the info, I need that body lift but also the suspension lift that's the problem
No problem there... In the subaru world a body lift includes the struts as well - there's no chassis to just raise the body from ;)
Wesvo
Post by Wesvo » Wed Aug 29, 2012 8:33 pm
El_Freddo wrote:No problem there... In the subaru world a body lift includes the struts as well - there's no chassis to just raise the body from ;)
It says the struts are not avaible for them!
I would lift 2inch suspension!
Thanks David
Thank you Bennie
