Ej20 no afm?
Ej20 no afm?
Just cleaning up the brumby's motor i just realised that there's no maf sensor on the intake or in the throttle body itself... Is there going to be any problem with pushing air into the motor (blower) without it running lean or too rich? if so any easy fix?
A little more info on the engine wouldnt go a-stray
Aftermarket ECU or factory?
By blower i assume you mean supercharger?
If it is map sensed and has a factory ECU, you are gonna have issues with adding boost.
If it has an aftermarket ECU, the fuel maps can easily be modified to accommodate boost
map based ECU's control the engine based on a pre-defined set of values for the tune, rather than paying attention to sensors like airflow and adjusting the tune etc to suit. This is why map based ECU's usually need to be dyno tuned to be tuned properly.
for example, Matt's old EA82 motor didn't have to have it's original air flow sensor anymore because it was running from a Microtech map based ECU - he had to get it dyno tuned when changing to a different turbo etc.
I didn't realise Subaru's used any map based ecu's, I thought they all used air flow sensors?
EZ30 L series - Monsterwagon
Which is better? I'm guessing the MAF sensored ECU's are easier all round to use in every day driving for best performance.AndrewT wrote:map based ECU's control the engine based on a pre-defined set of values for the tune, rather than paying attention to sensors like airflow and adjusting the tune etc to suit. This is why map based ECU's usually need to be dyno tuned to be tuned properly.
I too did not know that subaru used map based ECUs, actually, before this post I didn't know there was any different systems used...
- vincentvega
What i meant by map was Manifold Air Pressure.
Cars without an Airflow Meter usually have a Manifold Air Pressure sensor and calculate fuel input from a pre programmed table of MAP and RPM inputs. This is known as a 'fuel map' (what alex was refering to)
I too dont know of any soobs that dont have a MAF sensor
- steve_rising_sun
After about 2000 Subis use MAP sensors on at least the non turbos. I will have to wait Monday to look up which did or didnt.
Steve
Steve
Suparoo wrote:What i meant by map was Manifold Air Pressure.
