bizar wiring issues 1992 liberty
BrennyV
Post by BrennyV » Mon Aug 25, 2008 4:45 pm
OK, so Sunday I decided to remove all the aftermarket wiring including the alarm and make it all nice and factory again. but alas no fix for my bizar problems.
-wipers work with no key
-no accessory's
-both thermos are always on
-stereo and ciggy lighter are always on
ideas?
cheers
Brendan
Hunter S. Thompson
vincentvega
Post by vincentvega » Mon Aug 25, 2008 5:17 pm
someone has re routed a power supply somwhere.
both thermos always on - try turning off your AC
Post by Subafury » Mon Aug 25, 2008 5:39 pm
both my thermos are always on too. i dont have a/c connected.
check the connections at the key barrell maybe.
radio could of been wired wrong- easy to confuse those two power wires
BrennyV
Post by BrennyV » Mon Aug 25, 2008 5:55 pm
nah not the a/c i neva use it ;)
Hunter S. Thompson
BrennyV
Subafury wrote:both my thermos are always on too. i dont have a/c connected.
dosent explain the ciggy lighter and window wipers.
Hunter S. Thompson
Post by Alex » Mon Aug 25, 2008 6:16 pm
do your lights work without putting the ignition on?
BrennyV
Post by BrennyV » Mon Aug 25, 2008 6:19 pm
Alex wrote:do your lights work without putting the ignition on?
lights work as normal. (tho obviously been no accessorys not till its at on)
Hunter S. Thompson
Captain Obvious
Post by Captain Obvious » Mon Aug 25, 2008 8:34 pm
brenny and subafury maybe fans on all the time is a limp mode thing? missing sensor or something.
my lib did this, no T-state temp dropped to cold and fans came on...
BrennyV
Post by BrennyV » Tue Aug 26, 2008 10:49 am
not sure mate, atm i need to solve the accessorys and why the ciggy lighter/wipers/dek etc stays on, then i can get more of an idea if this is anything to do with the fans or not.
Hunter S. Thompson
AD7
Post by AD7 » Tue Aug 26, 2008 3:31 pm
I had my 91 Lib at the Auto elec last week to sort a bung horn relay. I asked him about the fans coming on all the time. He rang Subaru and they pointed out to him that the fans will come on when ignition is turned on when the climate control / heater / fan etc is also on. (Which is what I guess vincentvega was saying) So try turning all that gear off and see if it does it.
Aaron
Post by Subafury » Tue Aug 26, 2008 10:11 pm
and what if its a conversion haha spose theres a wire triggering it off somewhere. doesnt really bother me tho.
