loose shifter
- subie_1st_timer
loose shifter
ive touched on this before with people saying to replace the split pin with a bolt... well when i checked my shifter this little "modification" has already been done to the car before i brought it, but, the shifter is sloppy as now and getting really difficult to get into reverse (the other gears i find really easy tho) so is there another solution?
cheers
cheers
Have you checked the rubber bushes - they could be worn/broken down?
- subie_1st_timer
- bobbyjimmy
You get the parts at a Subaru dealer.
Ask them to see picture 330-2 in the Brumby book and these are the parts you'll need;
# 8 - 733229010 x 2 - Bush
# 9 - 633124170 x 2 - Bush
# 4- 733146090 x 1 - Bush
# 42 - 733127020 x 1 - Spacer
Then depending on how bad it is, you may need
# 15 - 733121020 x 1 - Lever
Another thing to try is to tighten up the bolt as much as possible untill you get new bushes did this to my brothers car and lasted a good 12 months probably more!
87 targa brumby (Neglected),
+ others.
+ others.
- subie_1st_timer
i just ordered new bushes and spacer, thanks for the part numbers bobbyjimmy!!! total cost $16.70!!! very surprised and impressed. pick them up this arvo
anything i need to know when fitting these and refitting the shifter??? is there a 'procedure' to do this job or anything special i need to know ie, box must be put be in 1st gear or something like that?
