Alternator wires ??
LongtimeAddict
Alternator wires ??
Post by LongtimeAddict » Fri Sep 12, 2008 5:03 pm
I am half way thru the EJ conversion - onto the wiring, and I have hit a snag :( the manual shows only 4 wires from the alternator White, White, BlackWhite & Yellow - but mine has a Green as well ??? Does anyone know what this extra wire is please.
Tony
99 Outback (stock at the moment) :rolleyes:
stamp_licker
Post by stamp_licker » Fri Sep 12, 2008 5:27 pm
Look here showthread.php?t=4260
Normally on the back of the alt is a wiring diagram/pin idenity
Which alt are you using the one with a round plug or a square plug?
Building a hardcore postie:D
LongtimeAddict
Post by LongtimeAddict » Fri Sep 12, 2008 5:49 pm
Thanks SL. I'm using the round plug type, 89 EJ S1G1. When I pulled the loom off the donor car I somehow managed to miss the alternator wires, seems they went thru the front loom (lights etc) rather than the EMS loom thru the mudguard. when I went to the wreckers to look for the wiring most of the cars after 90 had the wiring thru the EMS loom. The car is sitting at work (where I'm doin the swap) so I will check the sticker in the morning.
Once again thanks for your help :)
stamp_licker
Post by stamp_licker » Fri Sep 12, 2008 6:06 pm
the early ej alt had a sense wire which needs power when the ignition is on, this could be the green.If you can get a later alt ,no sensing wire and more reliable.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Sep 12, 2008 10:26 pm
Early EJ sense wire is the yellow one
The long road ahead
