Liberty CV to Brumby axle
- 2happypigs
Hi, can anyone tell me if the inner and outer CV joints will fit onto a Brumby axle?
This is for a trike project .
I am trying to achive a thinner wheel base.
I am using SVX motor and gearbox with Liberty hubs.
Thanks for the help.
Rusty
Rusty
- vincentvega
cant help you with your driveshaft question, but how are you planning on using the gearbox to only drive one axle?
if you were to fit a liberty 2WD auto rear end to the SVX 4WD auto box it would work well for you. H6 trike - kickass
- 2happypigs
- vincentvega
- the gumbi brumby
- 2happypigs
I rang driveline servics and they said they could not cut it down for me.
all I need to know is, are the splines on the on the Brumby shaftes the same as the Liberty. IE number of teeth and diameter.
I beleve the Brumby shaftes are about 100mm shorter. I was looking for a 5 inch shorterning but 100mm will do.
Thanks Rusty
Thanks Rusty
- the gumbi brumby
- Pommiebrat
