THANKS IN ADVANCE FOR ANY HELP.
Strange Noises
Strange Noises
MY 92 BRUMBY 4 SPD. EVERY TIME I CHANGE GEARS 1,2,3. THERE IS A HIGH PITCH WINDING NOISE. IT FIRST BEGAN WHEN I DROVE IT HARD....SILLY, I KNOW. IT IS A VERY WEIRD NOISE, ALMOST LIKE......THIS SOUNDS STUPID, LIKE A SUPER CHARGER UNDER THE HOOD.
does it happen when you push the clutch in?SUBANOOB wrote:MY 92 BRUMBY 4 SPD. EVERY TIME I CHANGE GEARS 1,2,3. THERE IS A HIGH PITCH WINDING NOISE. IT FIRST BEGAN WHEN I DROVE IT HARD....SILLY, I KNOW. IT IS A VERY WEIRD NOISE, ALMOST LIKE......THIS SOUNDS STUPID, LIKE A SUPER CHARGER UNDER THE HOOD.
Yeah thats right. It might be worthwhile replace the clutch while the box is removed, saves headache later. Otherwise you can just replace the bearing itself. If it was me i'll buy clutch kit and replace whole kit.Suba wrote:Thrust bearing , pull the box out and replace the thrust bearing , cheap and relitivly easy job.
Mike.
That's all the doughies you were doing in the mud:twisted:SUBANOOB wrote:MY 92 BRUMBY 4 SPD. EVERY TIME I CHANGE GEARS 1,2,3. THERE IS A HIGH PITCH WINDING NOISE. IT FIRST BEGAN WHEN I DROVE IT HARD....SILLY, I KNOW. IT IS A VERY WEIRD NOISE, ALMOST LIKE......THIS SOUNDS STUPID, LIKE A SUPER CHARGER UNDER THE HOOD.
You should have let us know at the meeting there was plenty of people who would have known
:-DYarney I Have Been Hesitant To Push Any Limits At The Club. I Know That It Is One Of The Benifits Of Being In The Club.
Alpine Raven. Yes It Makes A Noise When You Push In The Cluch.
:???:Question.... Is The Price Of A 5 Spd Conversion In The Same League As A New Clutch Kit And The Rest?.....should I Just Get A 5 Spd Now?
Alpine Raven. Yes It Makes A Noise When You Push In The Cluch.:???:Question.... Is The Price Of A 5 Spd Conversion In The Same League As A New Clutch Kit And The Rest?.....should I Just Get A 5 Spd Now?
- Suby Wan Kenobi
You will also need an An L clutch cable as the release is on the other side of centre line. L clutch plate is different to the MY clutch plate, you will also need an L series tailshaft. You will also need to match the box ratio with the diff raito. If you get stuck give us a ring.
The long road ahead
The long road ahead
