*temporarily* disable digital odometer
- SUBYDAZZ
I know a bloke who has just bout a 99-ish Impreza and he says on most cars there is a fuse somewhere that can disable the odometer when need be, is this true, and if so, what is it?
SUBYDAZZ
I doubt it. The only thing you could do is unplug the vehicle speed sensor.
- Outback bloke
It wont work, you'll have stalling problems, engine will run rich. Why would you want to disable odo?
- Outback bloke
- vincentvega
No you wont.AlpineRaven wrote:It wont work, you'll have stalling problems, engine will run rich. Why would you want to disable odo?
You could definately cut the speedo wire to the cluster but leave it connected to the ECU and TCU (if auto)
the speedo and odometer would both stop working though. Won't affect anything else
