how many Ks have you done a single tank
- the gumbi brumby
as abouve
reason for asking is today was driving around for work after a fair bit of hiway driving.
i reset the trip last time i filled up any way 548.4k i filled up 48L gave it 5 or 6 clicks yep its full
stock 1990 brumby ea81
normal unleaded
can you top this effort
normal unleaded
E10 BLEND KILLS CARBY CARS AND RUSTS STEEL TANKS
This is a bad comparison obviously as it's a totally different car but food for thought.
I can squeeze ~600 out of my RX if I try (EJ20 turbo) which is only an approximate figure. My odo is out due to several reasons but overall it's only slightly out.
- now running 4.1 final drive ratio (originally 3.7)
- now running RS turbo gearbox with different gear ratios
- now running larger 14" tyres
Come to think of it she's just about empty right now I'll take a photo...
I rekon I could hit 600 with it....I'll try in the morning and post another photo
This is on the standard 55litre L series tank, using any old RON95 fuel and not particularly trying to take it easy, still boost up fairly often while I'm driving.
I always reset the trip meter every time I fill up to keep an eye on millage.
EZ30 L series - Monsterwagon
ahahah,,,let me see here
80 litres of petrol, and 95 litres of gas gets me 800 kms......hmmmmm.....not very good
buggy, 20 litres of fuel got me approx 8 horus of rev limiter goodness at wedge
L series MPFI standard box/diff's and tyre diametre etc etc.
739km to 60 litres - did the drive from adelaide to central vic (woodend) on one tank
Car was lightly loaded and flogged everytime we passed a slow vehicle...
also, I think this is a bit of a chalk and cheese discussion - that said, I'm okay with it.
Speedo is run off the output side of the gearbox, gear ratios don't make a difference. But, the speedo's gear might be different (I doubt this because my 3.7 and 3.9 boxes both had the same speedo gear ratio).AndrewT wrote: - now running RS turbo gearbox with different gear ratios
Your diff ratio will change the speedo by 9.25%, so that is it will read faster then you are going. Depending on your tyre size, 215/75R14 tyres are about 18% over stock so you'd be looking at about 9% slow reading. In every 100km you'll read 91km on the odo. Of cause, every brands sizes differ, sometimes as much as half an inch OD for the extact same rated size. So without a tape measure you can't calculate how much out your speedo is.
Personally I don't like the "how many to a tank" measurement as it doesn't translate to other vehicles, or even different models. I always use l/100km. Easy to figure out using how much to a tank as well.
Doing the figures, my dads L series touring wagon would get 645km to a tank, and thats the 60l tank. But of cause, the tank isn't exactly 60l, I once put 62.something in it. But its running like crap with exhaust leaks and shit carby, so no wonder it only gets 9.3l/100km
i can get about 650 from atank in my liberty if driven nicely (thats from 45-50l approx)
wagon use to get about 450 to a 40l tank with ea82, ej22 and ej20g its slightly better again.
akex
akex
Alex ur wagon should have a 55L tank surely? I've always been able to squeeze around 58L in all my L series, aren't they all the same?
nup, i can never fit over 40l in my tank. But i never run it uber dry. I think ive once squeezed 45l into it. And no, its not dented.
actually don't mind me, from memory actually there might be a difference between the Touring Wagon models and others. And I guess my RX sedan has the larger tank too.Keffa wrote:nup, i can never fit over 40l in my tank. But i never run it uber dry. I think ive once squeezed 45l into it. And no, its not dented.
After I posted that photo of my dash the other day I got it to 587 before pulling into a servo and filling up, fitted 58litres in after a few clicks.
A few days later now and I managed to get 607kms out of it. She's pretty much bone dry now, stuttered slightly going around the bend just near my house
Ditto above - got near on exactly this when the engine died due to no petrol(had another 10 litres in the boot...teehee)El_Freddo wrote:L series MPFI standard box/diff's and tyre diametre etc etc.
Needs a tune now as I am only getting to sydney and back on a tank(mind you I have been using the 91 RON stuff)
Hooroo
Rob Forsyth
yeah, just normal economy for a Liberty RS turbo really. Maybe slightly better due to a couple of hundred kilos weight reduction being in an L series.steptoe wrote:Wow, Andrew, is this an EJ20 turbo'd RX as in L series. Nice economy !
