Converting 1997 SUBARU LIBERTY 2GEN MY97 RX AWD to manual
Just wanted to know if it can be done easily
If so, how much for parts and what parts are needed
thanks in advance
thanks in advance
I am guessing its automatic at the moment -
You have these options below -
Convert to Dual Range AWD or Single Range AWD.
You'll need:
Correct ratio rear diff.
Peddles for clutch & brake.
Manual trans centre console
if you're gonna get cable clutch then thats easy you won't need hydraulic clutch master unit, if you do if the gearbox has it then thats more work for you.
If you're getting dual range you will need the lever.
clutch kit (pressure plate, bearings and disc)
manual transmission flywheel
manual transmission cross member
I think you'll also need tailshaft as well.
Cheapest way is to get a donor car!
You'll need:
![Image](http://i14.photobucket.com/albums/a313/tmerritt/PICT0927.jpg)
If you do go ahead,... do you wanna sell your auto box cheap?
Since he is in Victoria, you won't need to go on the pits or something, just let vic roads know that it has changed the stats... since its an RX Lib, its a 2.5 litre engine and it would be hard to find another RX that is manual.
I would do the same thing if I had an RX Liberty and i would have fitted in an modified dual range transmission (I almost bought an RX few years back but body was stuffed)
