Hydrolic lifters noisy
someguy
Post by someguy » Mon Feb 16, 2009 12:26 pm
Hi guys.
Had my L series for over 2 years now and just recently when I start the engine I get a loud ticking noise. I have been told this is an issue with the hydraulic lifters. Does anyone know what causes this and what is the best way to fix it.
Thanks
Post by El_Freddo » Mon Feb 16, 2009 2:26 pm
Yeah, this isn't really a problem, more so a coming of age for the EA82's ;)
To help resolve this problem you can replace the seals on the oil pump, make sure you do the shaft seal too.
Other than that you either put up with it or do regular oil changes to try and clean them out over time...
someguy
Post by someguy » Mon Feb 16, 2009 3:01 pm
thanks mate.
Im getting it serviced for the first time in around 14 months tomorrow (don't judge me haha)
Hopefully that will flush it out a bit.
Might ask the mechanic to replace the seals aswel
Post by El_Freddo » Mon Feb 16, 2009 3:13 pm
someguy wrote:Might ask the mechanic to replace the seals aswel
That'll be a bit costly if you're not doing it yourself, but if you have the money go for it - get him to replace the water pump at the same time and maybe the cambelts if you want as they're all in the same area/need the same things removed to get to them...
someguy
Post by someguy » Mon Feb 16, 2009 3:41 pm
El_Freddo wrote:That'll be a bit costly if you're not doing it yourself, but if you have the money go for it - get him to replace the water pump at the same time and maybe the cambelts if you want as they're all in the same area/need the same things removed to get to them...
My mate is my mechanic and does not charge me for the labour on any jobs. which is great.
So hopefully won't be too much.
subybrumby
Post by subybrumby » Mon Feb 16, 2009 3:42 pm
Mate, I had this problem, and it sounded real bad. I've had some success though and it seems to be running quite good at the moment. See here :-
showthread.php?t=12953&highlight=lash
Kieren
Post by Kieren » Mon Feb 16, 2009 7:54 pm
i had the same trouble with my EA82.
i was told it was the oil releif valve and spring, and the parts were cheap from subaru aus.
but when it came to the actual replacement of parts, i had to replace the whole oil pump. this fixed it up instantly.
hope this helps
1989 L Series Wagon
3" lift, 27/8.5/R14 Muddies
EJ22
