TACHO not working!!
H-top
TACHO not working!!
Post by H-top » Sun May 31, 2009 4:51 pm
G'day all
I've got a vortex with an EA82 MPFI NA '85.
My tacho has stopped working, but i have not blown a fuse?
i run an aftermarket coil and have had it in for months and
i was driving today and it suddenly stopped, no warning,
no super high revving, no noise, just stopped!!??
any ideas?
H-Top
rolling in
Post by El_Freddo » Sun May 31, 2009 9:00 pm
Several things:
1) a dodgy connection on the back of the instrument cluster has caused the issue
2) the L series subarus (AFAIK the vortex too) have issues with the tacho working in the heat - this can be from the car sitting in the sun in the middle of winter to using the demister on full ball for too long. It will usually come good with a tap, a bump on the road or a bit of hard revving...
3) something's crawled into the instrument cluster and died in a position to stop the tacho working :rolleyes:
Probabily not real useful stuff here from me - have you traced any wiring to check it out?
Post by steptoe » Sun May 31, 2009 9:08 pm
My L series tacho has stopped from time to time, got stuck on 1000rpm but tends to work most times. Might be OK next time??
H-top
Post by H-top » Sun May 31, 2009 9:47 pm
I really really don't want to take the dash out of the vortex lol so much work!
Which is the signal wire of the two from the dizzy? Cheers, sam
H-Top
rolling in
mattl200
Post by mattl200 » Mon Jun 01, 2009 10:57 am
should be the yellow red wire from the negative side of the coil
well it is on the brumbys and lseries
