2001 Outback trailer wiring help
My outback has a towbar, but i cant find a trailer wiring socket (the 7 pin flat type)
Assuming that the previous owner didnt have one, or he removed it before selling it, i bought a length of 7 core cable and a 7 pin socket.
What to i connect it to? Is there a special plug designed for connecting the trailer harness to?
- justincase41
Have a look in the rear boot well, or any rear cargo compartments. I can't recall from memory if the 2001 outback had any or not. Most factory installed trailer sockets are now being installed so that the plug can be tucked away inside the vehicle.
Current :
1992 Brumby (Future EJ20 Conversion)
2007 Toyota Prado 120
2012 Great Wall V200 (daily driver)
1997 Subaru Outback
1999 Toyota Surf (Beach Basher)
Past:
To Many to list!
1997 Subaru Outback
Past:
To Many to list!
- BaronVonChickenPants
Thanks Jordan
So is that the white, 10 pin plug?
Did you cut your plug off, or did you find a socket that matches it?
10 pins sounds about right, I didn't cut the plug off as I don't like making changes that can't be undone, I just tinned the end of the wires, inserted them into the plug and taped it up when I was done.
I conveniently had a removable light board from a boat trailer handy when I did mine, between that and the trusty multimeter it was done in no time.
Jordan.
Jordan.
Ok ive done it.
I ended cutting off the plug and soldering/ heatshrinking the connections cos i needed to tow the trailer today and couldnt wait till next week to buy a matching plug.
The wire colours are as follows
Car wiring ----- Function ----- Trailer wiring ---- 7 Pin Flat plug No.
Black-----------Earth-----------White--------------3
Blue/Red-------12v Aux----------Black--------------2
White/Black----Stop Lights--------Red--------------6
Lt Green/Black--Turn Right--------Green------------4
Black/Blue------Tail Lights--------Brown------------7
Black/Green----Turn Left---------Yellow------------1
no wire--------Trailer Brakes-------Blue------------5
This is of the soldered connections with heatshrink over them (i still have 1 to go)
This is after i wrapped it all up in insulation tape, ready to push back into the compartment.
The blue wire with the connector on it is for if i ever get electric trailer brakes
