Removing Lift Kit
Removing Lift Kit
I am thinking about removing the lift kit out of my Brumby. Was wondering what length bolts and how many of each, I will need to replace the ones removed with the lift kit. Would much rather be able to have everything ready to go before starting rather than taking it all apart, measuring the bolts I remove, minus the 2 inch for the lift then getting the bolts needed.
Cheers Nick
Cheers Nick
- Outback bloke
What does the ute have behind the engine because your ute may need the clearance in the transmission tunnel my auto needs the space hence why mine has a lift kit! But If you don't sell to Ian then you might be best going to a wrecker and buying the bolts you need as well as the steering knuckle etc!
87 targa brumby (Neglected),
+ others.
+ others.
dukbilt wrote:Is the lift kit still available?
Ewan
No, I am currently unsure if I'm going to lower the brumby or run the lift so will be keeping the lift kit until I make up my mind. Also for other peoples info I have removed the strut spacers and all the rear components of the lift kit, still utilising the engine, gearbox spacers and steering shaft extension and have had no issues. It has flattened out the rear driveshaft angles and also the front cv angles so there should be longer life out of the front cv's hopefully.
- phillatdarwin
