crankcase pressurising big time
- dirty skirt
g'day all
im having a big problem with my ea81,i put a post in the other day about the timing cause i thought it was only the dizzy o-ring pissing out oil but now its from the dizzy o-ring,sump gasket,rocker covers basically everywhere possible.its pressurising the crankcase big time(talking about taking dipstick out and nearly hits you in the forehead).
Now ive checked the valve on the inlet manifold that holds the hose comin from thehose that joins to the rocker covers.it was blocked but i freed up and is working fine now
ive also done a compression test and has 1275 kpa in all for cylinders.
ive also did the same test but with oil in them and they were 1325 kpa in the 1st 3 but in the 4th it had 1310kpa,to me they are perfect.
can anyone help me out has anyone had the same happen to them or seen this happen.i dont have a oil pressure tester so i cant do that,the car runs perfect but uses a tiny bit of coolant.
if any one can help that would be very very appreciated
thanks steve
thanks steve
- dirty skirt
- dirty skirt
- dirty skirt
- dirty skirt
Check your breather hoses, I haven't had this problem on an N/A, but i have pulled off breather hoses that black crap just seems to keep coming out of, if these are blocked it wont help much.
You should only be able to blow through the PCV valve from the hose end not the threaded end, probably not so critical on an N/A though
- Suby Wan Kenobi
- dirty skirt
