Subie Boys , Lovey80 Resto
- last celtic warrior
Whats the proposed driveline for this car going to be?
EJ engine but what one exactly, and what gearbox etc?
EZ30 L series - Monsterwagon
Hey Andrew T, The engine is a Ej 22 followed by a L series d/r center diff lock 5 speed ( the L series RX box i believe they come out of ) and at the end, when we find on, a clutch pack lsd.AndrewT wrote:Whats the proposed driveline for this car going to be?
We have been shopping today, ( if ya wish to call it that) , lol. Picked up a set of L series rear disks .
rtcb65
Redneck Rick.
Redneck Rick.
They seem to be in good nic, all you can see that dont look nice , is cosmetic. It will be cleaned up. I will get the disk rotors microed to see if there is enough to machine . It is always better to machine disks and put new pads on. That way they can bed together.lovey80 wrote:Good job mate thats one more item off the list! What nic are they in/ Do you think theyll need machining?
Chris
rtcb65
Redneck Rick.
Redneck Rick.
Geez, you guys are pulling some tricks now arn't you?! Good find on the discs, I pieced mine together - lack of funds and a lack of tools when I found a complete set...
I didn't bother micro'n or machining my discs, I whacked the rusty ones on, went for a drive and made sure I applied the brakes firmly from speed afew times, they're all good now and have never had a problem with them. I love the bite (brake grip/performance) they give when you use them a little bit more than you would with normal driving, that's where I really feel the difference.
Hey Bennie, thanks for the comment about the tricks. Steve's talent helps. We come up with idea's , the hard part is to make it reality.El_Freddo wrote:Geez, you guys are pulling some tricks now arn't you?! Good find on the discs, I pieced mine together - lack of funds and a lack of tools when I found a complete set...
rtcb65
Redneck Rick.
Redneck Rick.
Its Thursday so Steve has been playing again.
Around the wheel well there is a raised area so all the water and all the other stuff that finds itself in a ute tray can be funneled away from going into the well.
The base of the well all made up including drainage help so any water can find its way under the tire and drop out the drain hole.
The well base sitting in place. Bottom view.
And the top view. Just the side pieces to be made up and it can go in.
rtcb65
Redneck Rick.
Redneck Rick.
- vincentvega
The sec i saw it sitting there, that is the first thing that went through my mind as well. So we checked the tail shaft future position and it will clear. With the 2 to 3 inch lift ( depending on the final decision ) it gives plenty of room . In theory. Yet to check in practice.vincentvega wrote:the tailshaft wont hit that? Beautiful metalwork..
rtcb65
Redneck Rick.
Redneck Rick.
The wheel well is now finished and of course we just had to try it out. lol.
rtcb65
Redneck Rick.
Redneck Rick.
Oh, about the tailshaft concern...
With the 2 inch lift this car has, there is actually still more clearance between the tailshaft and the spare wheel well than there was between the tailshaft and the tunnel originally.
And... Yes, it's all hammered out of sheet (as always)...
Steve.
- BARNES AUTOMOTIVE TECHNOLOGIES -
Hey 32ford,32ford wrote:maybe you guys should relocate the battery next to that spare wheel well and eliminate that troublesome battery tray dent that is too close to big front wheels. beautiful work you guys do btw!
Your suggestion is half right. The battery tray is removed and a new one is going to be made to suit the other side. As were it was , is where the air fillter is going. Beside the wheel well , there is to be a box made to take a back up/accessory battery . IF we can make it fit.
rtcb65
Redneck Rick.
Redneck Rick.
i hope you did 2 m8.
you know i wanted the same thing lol.but im wanting that to .
as for the lift thinking wouldnt a lift move it away from the tailshaft ?
or is that aftr lift . if so how would it sit on a standard ride . as i want to lower mine member. iv only got to get a few other things to get ie the rite front shafts and brakes i think mabe a aly raidator if i can find one hehehehehehe
dibs
dibs
