Liberty Auto Question
Chris_Rogers
Post by Chris_Rogers » Sat Mar 18, 2006 11:44 pm
are these set up the same as the L Series ones? IE shift linkage.
the L series has a Rod that connects to teh shifter and then to the box.
what does the liberty auto use?
(I'm trying to get all I need BEFORE I do the swap.)
Audio Express
1987 HR31 Nissan skyline
1990 R32 Nissan Skyline GTS4
jzk25
Post by jzk25 » Sun Mar 19, 2006 12:09 pm
Cable from shifter to box.
Chris_Rogers
Post by Chris_Rogers » Sun Mar 19, 2006 1:36 pm
how does it attach to the shifter- with a pin or a bolt?
Audio Express
PeeJay
Post by PeeJay » Sun Mar 19, 2006 2:42 pm
From memory the one I had used something similar to an accelerator cable. Could be wrong.
jzk25
Post by jzk25 » Sun Mar 19, 2006 3:21 pm
Cables outer anchors on shifter body and inner has a long thread with wo 12mm headed 6mm thread lock nuts that go thru an eyelet.
Chris_Rogers
Post by Chris_Rogers » Sun Mar 19, 2006 4:44 pm
perfect- it will bolt straight to a L series shifter then. Ta!
Audio Express
