V8 Conversion
Post by El_Freddo » Sun Feb 21, 2010 11:45 pm
Anything's possible if your pockets are deep enough! There's a mini getting around in the UK that's got a range rover V8 running on the standard box!! The thing looks standard from the exterior until it's fired up or the bonnet is lifted. Not a lot of space available under there!!
Retaining the hi/lo gearbox will be near impossible without extending the nose of the L forward, making the thing look weird. Someone's also mentioned the weight over the front axle issue. The best way to do it would probabily use the X8 system that holden used from subaru - getting it all to fit would be the thing to work out though. It would be a mean piece of kit if you could get it all sorted. Let me know when you get it engineered as I'd like to know about it!
drof351
Post by drof351 » Sun Feb 21, 2010 11:53 pm
Can you move the gearbox further back and modify the linkages? Or maybe a gearbox and transfer box out of something else?
GOD
Post by GOD » Mon Feb 22, 2010 12:13 am
You could widen the transmission tunnel, fabricate mounts and linkages and move the gearbox aft, but then the front diff would be too far from the front hubs. To keep four wheel drive you'd have to use a different box and transfer case.
Might be easier to plonk a Sube body on a chassis from something else. It's been done with a Brumby body on a Hilux chassis with a Commodore V6.
Dane.
Post by Alex » Mon Feb 22, 2010 10:18 am
this thread is gay. Go buy a commonwhore.
Post by TOONGA » Mon Feb 22, 2010 11:03 am
Keffa wrote:this thread is gay. Go buy a commonwhore.
ouch
so if i was to put a V6 into my brumby that would upset you Alex? :)
Post by Alex » Mon Feb 22, 2010 11:12 am
TOONGA wrote:ouch
no because theres a mutual respect between you and your subarus unlike other members on here.
Post by Gannon » Mon Feb 22, 2010 11:29 am
Why would anybody bother putting an V6/V8 in a Subaru when for what you would spend on chassis modifications, you can very easily fit a worked STI motor in and get just as much power out of it.
Post by TOONGA » Mon Feb 22, 2010 6:51 pm
Suparoo wrote:Why would anybody bother putting an V6/V8 in a Subaru when for what you would spend on chassis modifications, you can very easily fit a worked STI motor in and get just as much power out of it.
the same reason Im going to get an ej motor to run with a distributor and a holley carby
because I can :)
subybrumby
Post by subybrumby » Mon Feb 22, 2010 11:23 pm
Well, this thread has caused some heat...
Ok..Suparoo has hit the nail on the head..Subaru motors develop much more horsepower than most small V8's as a virtual bolt in proposition,.
There is a thread on this in the states I was looking at the other day and the guy was trying to put a fairly hefty V8 into a WRX..The project was finally abandoned and he was trying to sell the rex as an unfinished project...result, no takers...(I'll try and find the link). Looking at the photos, the car was an abortion and the project a disaster.
The only viable prospect as mentioned earlier would be the 3500 (3.5l) rover alloy V8. These motors are fairly cheap and easy to aquire and are alloy. But still, there would be inherent problems in shoe horning the engine into the space and I would think that the four wheel drive option would be out of the question. IF ?? a project were to proceed, the most likely prospect for success would be the rover V8 to be inserted with its matching gearbox and the unit moved as far back as it would go and linked directly to the tailshaft and rear diff. But what would you achieve?? These engines do not develop anywhere near the horsepower that would be developed by an EJ20T and the only gain would be, ok it sounds like a V8 and the curiosity value at a meet.
We are not even looking at the engineering requirements and the chance of having the thing certified for road use (QLD). I 'm pretty sure that in Qld, you are not allowed to insert any engine that is older than the car. In other words, any donor engine must come from a vehicle that is of the same age or younger than the transplant vehicle.
There are some good sites on the net that show the Rover V8 as the engine of choice for repowering of MG sports cars, but these also have a longer engine bay.
For your information, the rover V8 is 650mm wide and 770mm long. Get the tape out and have a look, let me know if you are prepared to spend hours lying under the thing wondering is this gonna work, or should I just go EJ.
http://www.clubwrx.net/forums/engine-mo ... -swap.html
32ford
Post by 32ford » Tue Feb 23, 2010 12:06 am
spike
Post by spike » Tue Feb 23, 2010 9:02 am
32ford wrote:this one would fit
http://www.moyermade.com/chevyV8.html
saw this a few years back before i was on ausubaru.
very happy to find it again thanks.
im so tempted to do some modeling like this, already thinking of a flat 4
Post by RSR 555 » Tue Feb 23, 2010 10:14 am
hahahaha.. love it !! Just need a miniture '32 to put it in :D
Post by Alex » Tue Feb 23, 2010 1:29 pm
i want to do an ej207 conversion to my HQ GTS. I want to use the STi 6 speed box and make it awd.
i also want to do a strait thru 4inch exhaust with twin 6inch cannons on the back, paint it wrc blue and have gold rims.
opinions?
GOD
Post by GOD » Tue Feb 23, 2010 1:43 pm
Keffa wrote:i want to do an ej207 conversion to my HQ GTS. I want to use the STi 6 speed box and make it awd.
opinions?
hahaha post that on oldholdens.com and watch the reactions :D
Dane.
Post by Alex » Tue Feb 23, 2010 2:12 pm
EXACTLY the point im trying to get across.
Post by RSR 555 » Tue Feb 23, 2010 4:29 pm
opinions?
You must have the 8" tacho with the super blinding shift light screwed to the centre of the dash with roofing tek screws :p
Post by TOONGA » Tue Feb 23, 2010 5:25 pm
opinions?
I fell off my chair when I read that (truely I did) and Im still laughing
even with the power of an EJ20T Im pretty sure a HQ wouldn't move
But hey Im pretty sure it would sound better than a 202
Post by Gannon » Tue Feb 23, 2010 5:30 pm
RSR 555 wrote:You must have the 8" tacho with the super blinding shift light screwed to the centre of the dash with roofing tek screws :p
Yeah,... why do young car enthusiasts put big tacho's in their cars, even if the car already has a factory tachometer? I really dont see the point.
Outback bloke
Post by Outback bloke » Tue Feb 23, 2010 5:57 pm
drof351 wrote:Hi, Has anyone put a V8 into an L series? Keeping the 5 speed hi lo?
This is the original post. Must be some thing wrong with my eyesight, I can't see it written any-where asking for opinions on what you think of the idea.
Pointing out that it isn't viable is fine but bagging the bloke for asking is not on.
someguy
Post by someguy » Tue Feb 23, 2010 6:10 pm
Outback bloke wrote:This is the original post. Must be some thing wrong with my eyesight, I can't see it written any-where asking for opinions on what you think of the idea.
Very well said.
I would love the idea of dropping one of my favourite engines (327 Small Block) into one of my favourite cars (L Series/Leone)
For me it would be like having the best of both worlds.
I know it would probably cost anywhere up to $35,000 to do but if I had the money I would
To answer the OP's question, sure it can be done, but be prepared to spend your life savings doing such a thing. Anything is possible if you have the $$$
