Blocking off heater hose in L series??
hey guys,
As the title suggest i was thinking of blocking off the heater hose to the cabin with a tap so i can cut it off in summer. I've done this to most of the old cars i've owned (EH's and Valiant) and it does do alot to cut down the heat coming into the cabin. Is there any reason i shouldn't do it to the L series?
Rhys
Rhys
The heater core is divided from the air flow when in cold mode. There really should be no need to turn off the water.
Unless the valve is faulty..Suparoo wrote:The heater core is divided from the air flow when in cold mode. There really should be no need to turn off the water.
The way you'd have to do it is to put in two taps (or three if you really wanted to isolate the heater core) and a H piece. In between the two hoses you'd install the H piece with a tap in the middle, the other one or two taps on the heater size of the H piece.
This will effectively isolate the heater core, especially with three taps, and still allow your motor to circulate the coolant to keep the thermostat happy, stop this circualtion you''re thermostat won't open in the EJ. Only down sides are:
1) if you need your heater you have to pop the bonnet to turn the taps around to use the heater core
2) If all three taps are off, you'll have no flow at all and your thermostat won't operate properly.
I've got mine hooked up as per factory without any heat issues in the cab, unless you've got a cracked heater core - I've solved that problem for some time by replacing the heater core with an all copper one
What valve?AlpineRaven wrote:Unless the valve is faulty..
Its a mechanical flap that is controlled by a vacuum servo. The water flows through the core whether its set to hot or cold
Close. But it is controlled by a cable through a gear set. So trivial!Suparoo wrote:Its a mechanical flap that is controlled by a vacuum servo. The water flows through the core whether its set to hot or cold
There must be something wrong with this mechanism if there's heat in the cab - or something wrong with the heater core as I've mentioned already.
Hey you are right.Close. But it is controlled by a cable through a gear set
Thats the 2nd time ive corrected tonight. I must be having a bad run
Thats exactly what i was wondering Bennie! Thanks for the responses guys. H piece is too much effortEl_Freddo wrote: This will effectively isolate the heater core, especially with three taps, and still allow your motor to circulate the coolant to keep the thermostat happy, stop this circualtion you''re thermostat won't open in the EJ.
I am thinking my headers may also tranfer alot more ambient heat through the floor than the standard setup.
Rhys
Dynamat it then that will not only cut down on heat transfer from the firewall but also noise creating a more comfortable ride all round.
87 targa brumby (Neglected),
+ others.
+ others.
