I was the unfortunate victim of a failed split pin on a dirt road at 60kmph yesterday. Result of said failure was the rattling off of the castleated nut that holds the wheel onto the control arm. End result - right front wheel bounced out of control arm after hitting a pothole and ended up embeded into the wheel well. The force of the action pulled the inner cv joint out (but the boot survived, no leaks?!?!!!) and stripped the thread of the control arm - steering knuckle bolt..
Managed to steal a nut from the rear diff hanger that rethreaded onto the bolt, and a wheel nut went onto the diff hanger. Rebuilt the CV joint and managed to get home ok - just.
When I first saw the damage the lift block and strut top where sitting straight and pretty, however the strut itself was about 30 degress forward (visible in pic).
When turning left even slightly I get monster wheel wobble and it sounds like the wheel is trying to tear itself off.
I called subaru, $165 for a new strut top! I'm hoping there is a wrecker out there willing to part with a pair of gen 2 outback strut tops...
Moral of the story - CHECK YOUR SPLIT PINS!
Owen.
