Keffa wrote:that offset thing is utter crap. My l-series had the speedy 14inch rims on it from new pretty much (receipts to back it up)
20 years later and with 340km on the clock (add 10% for bigger tyres its whole life) so close to 400k the car had no problems. Everything was replaced die to old age and wear rather than 10mm of extra offset on the rim.
Wheel offset is not utter crap,having built and driven Rally cars for longer than I care to think about people are aware of the negative effect the wrong offset has.Sure in some instances the factory overengineers components so there will not be reliability issues,but to much offset will increase the leverage and where you will feel this is steering wheel kickback on rough terrain.
The result can mean broken thumbs as the steering wheel reacts violently to the wheel hitting a bump,the problem with changing wheel offset is rarely can we find enough or any adjustment to compensate.
I have spent a full week adjusting the pickup points for a double wishbome front suspension on a Cobra race car involving cutting off the original mounting points and relocating them as needed temporarily and then running the suspension through full travel on a four post hoist with the wheel alignment jig reading the toe changes.
It started out with a Toe change of 38mm between static ride height and full droop and a change of 21mm under full compression,it ended up with 2mm variation from fully compressed to full droop.
This means that when the car became either airborne or very light on the suspension when it landed it no longer tried to spear off the road in an unpredictable manner,most cars do not have the benefit of having this type of effort expended on them and this is where the correct offset wheels are vital to keep the car controllable under any expected driving conditions.
The faster or more extreme the conditions are the more important this becomes,and this is why people used to run 5.5 inch front rims on rear wheel drive rally cars to keep the affects of steering kickback to a minimum by remaining as close to factory offset as possible.
If you do not believe me then make some radical toe adjustment to your car and go for a short drive,then you will change your mind about the affects of steering geometry and wheel offset.
