Impreza dual range box ratios
Venom
Post by Venom » Fri Apr 09, 2010 8:51 am
Hey guys,
There is a dual range Impreza RV at my local wreckers and i was wondering how i could tell if it was a 1.5 low range ration model?
Rhys
Venom
Post by Venom » Fri Apr 09, 2010 2:42 pm
June 98 Impreza sportswagon, not RV. Transmission code TY752XR6AB
Is there any way to look up the transmission number? I've had no luck on the internet.
Rhys
yarney
Post by yarney » Fri Apr 09, 2010 3:56 pm
I think it's the ej18 motor
Jan
d_generate
Post by d_generate » Fri Apr 09, 2010 4:57 pm
I had a 98 Impreza 2L Sportswagon for a short time & only ever stuck it in low once just to see what it was like, bloody high gearing from memory & felt like it wouldn't have done 70kph in 5th but have no idea what the ratio's were.
Captain Obvious
Post by Captain Obvious » Fri Apr 09, 2010 5:12 pm
i believe they are shit hot low range!! subaman will be able to tell you what it is, from what ive been told its pretty close to a L series 3.9ratio box. Just Buy or pull it and send it to me!!!
Post by El_Freddo » Sat Apr 10, 2010 9:00 am
Yeah Rhys, I'd be pulling it anyway, you need a dual range box :twisted:
I always thought that the impreza boxes were the 1.4something to 1 low range, with is bloody better than the 1.19:1 standard in everything else that's EJ and dual range...
Post by AlpineRaven » Sat Apr 10, 2010 10:44 pm
nah guys... I'm pretty sure it already has 1.59:1 if its coming out from EJ18 or EJ20.
Post by AlpineRaven » Sat Apr 10, 2010 10:52 pm
AlpineRaven wrote:nah guys... I'm pretty sure it already has 1.59:1 if its coming out from EJ18 or EJ20.
Correction - Its 1.592:1 Low Range.
Venom
Post by Venom » Sun Apr 11, 2010 5:23 pm
Is there actually a way to check based on the transmission number with Subaru or am i wasting my time with that? I'm really having zero luck using the number with the information available on the internet.
I'll go back and have a look at the car (again), and see what price they want for the box. I guess if its not 1.5whatever then i'll just need a L series low range.
Rhys
ScubyRoo
Post by ScubyRoo » Sun Apr 11, 2010 5:50 pm
Perhaps if you write down the VIN and then give that to Subaru, they might be able to tell you what was spec on that particular model???
There might be a part of that serial on the transmission that could help you out... but I think if that tranny was standard with the car then subaru should be able to tell you what ratio box came with that VIN.
I've found the parts bloke at the frankston subaru pretty good, try him at 9786 6900.
Good luck and let us know if it works out!
Owen.
Post by AlpineRaven » Sun Apr 11, 2010 9:54 pm
ScubyRoo wrote:Perhaps if you write down the VIN and then give that to Subaru, they might be able to tell you what was spec on that particular model???
Owen.
Ive done that kind of thing - they were useless (as they couldnt tell me specific answer (low range) but give it a go tho..
Venom
Post by Venom » Wed Jun 02, 2010 2:33 pm
Subaru are useless and have no information on this kind of thing. Wreckers aren't much better. I'm not in a rush to put a dual range in my car so i'd like to take the time and pick the right one. I'm not keen on putting in an impreza box to find the ratios won't suit. I find it hard to believe there can be 3 or 4 transmission charts but no one knows anything about these?
Post by AlpineRaven » Wed Jun 02, 2010 9:47 pm
Venom wrote:Subaru are useless and have no information on this kind of thing. Wreckers aren't much better. I'm not in a rush to put a dual range in my car so i'd like to take the time and pick the right one. I'm not keen on putting in an impreza box to find the ratios won't suit. I find it hard to believe there can be 3 or 4 transmission charts but no one knows anything about these?
Oh yeah they are... you gotta push them (if they are nice enough to let you look at thier books) but you wont be able to get complete information, they dont know what ratios that gearbox if you give them the gearbox number, its really annoying...
Venom
Post by Venom » Sat Jun 05, 2010 6:37 pm
Charts i have found so far...
http://www.northursalia.com/techdocs/tr ... chart.html
http://www.gearhack.com/myink/ViewPage. ... on%20Chart
http://members.iinet.net.au/~wearne/Sub ... 0Specs.pdf
Not one dual range on any of them.
Found a little hint of information on NASIOC referring to what the transmission code means, but it doesn't describe all possibilities... just ends in etc.
Code i am looking at is.. TY752XR6AB. T = transmission, easy. Y is manual gearbox. 75 is the gearshaft spacing. 2 is for 4-bolt impreza 5speeds. X is for transmission specification, no idea. R6AB indicates things like front diff and minor production changes, but no info on exactly what they indicate.
Post by AlpineRaven » Sat Jun 05, 2010 10:04 pm
Venom wrote:Charts i have found so far...
I did a rough work out a while back, cant find the files on my laptop but will get back to you tomorrow or other day..
Post by TOONGA » Sat May 05, 2018 3:19 pm
talk about digging up the past, I have been able to dig this up for one of these transmissions AWD TY752XR6AB
Impreza 1st Gen GF8 1992-2000
Model Number:- N/A
Chassis Number:JF1GF8KJ4WG025327
Engine Number:EJ20 ENW6FA
Engine Size:2000
Engine Type:4 CYL
Transmission Number:TY752XR6AB
Transmission Type:5SPD
impreza gearbox 32000AE410 TY752XR6AB
TY 75 MT
2 CAR BODY SERIES
X ViS-C center diff 4WD D/R [TY752]
R 2.0 l engine
last 3 numbers denote part ordering referring to gearbox revision for gearbox rebuilding
6
A
B
anyone have an FSM for an AUStralian delivered EJ20 single cam impreza wagon
Post by RSR 555 » Sat May 12, 2018 1:06 am
TOONGA wrote:talk about digging up the past, I have been able to dig this up for one of these transmissions AWD TY752XR6AB
Model Number:- N/A
Engine Size:2000
Engine Type:4 CYL
TY 75 MT
2 CAR BODY SERIES
R 2.0 l engine
6
A
B
WITHOUT SOUNDING PRESUMPTUOUS
Pretty sure your info you have found on google isn't true, as the GF8 refers to the EJ20 turbo variant and these were not available with the dual range gearboxes. GF6 (EJ18 & EJ20 NA) were available with the dual range gearbox in the "Sportswagon" model.
I have a copy somewhere of the AUDM FSM for the gen1 (GC/GF) Impreza but since I moved from Kelmscott, I've not been able to locate any of my manuals.
As for the original poster (8 years ago :???: ) the info you were chasing would have been 1:1.447 ratio
Post by TOONGA » Sat May 12, 2018 8:24 am
I always thought that presumptuous was your middle name ;)
so this line Impreza "1st Gen GF8 1992-2000", should read Impreza "1st Gen GF6 1992-2000". I got the vin number and other information from a wreckers website, as for its accuracy NFI.
However a Subaru dealership has confirmed this box TY752XR6AB is 3.9 final range with 1:1.447 low range ratio.
Post by RSR 555 » Sun May 13, 2018 12:20 am
I thought it was carmella?
Would never post info from a wreckers page.. asking for trouble there.
And I wouldn't have posted the ratio if it wasn't correct
wagonist
Post by wagonist » Sat Jun 02, 2018 11:37 pm
So what vehicles do those transmissions belong to? I always thought it was only the late 90s 2L Impreza sportswagon that had the "good" low range.
Been half contemplating putting a diesel in my touring wagon project, but they only came with a single range 6 speed. Might need a bit of screwing around with gear or diff ratios, etc if going to put a petrol trans behind it.
US sites are useless for this kind of info. They barely got any dual range L series, let alone anything newer
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
