1998 Gen2 seats into 1984 MY wagon
subaruby
Post by subaruby » Tue Jun 22, 2010 9:13 pm
Been wanting to upgrade the seats in the wagon for a while now and finaly got the oppurtunity when I replaced the seats in my ge2 Liberty.
Started with the passenger seat and to my delight the rails on the liberty seat were bolted on. The MY seat rails are also bolted on so things were looking good. So took the rails of the My seat and put them on the Liberty seat.
Original Liberty seat.
No rails
My seat rails on
The my rails bolted to the front holes on the liberty seat but I had to drill new holes to bolt the rear of the rails into.
I then sat the seat into the car. The side nearest the transmisson tunnel fitted perfectly. The side nearest the door not so good.
Door side front
Door side back
So I just re drilled some holes to suit,
The drivers side was to so easy as the rials were attached differently due to the height adjustment
Front rail mount
The MY seat rail bolted easily to this. I had to grind off the rear of the liberty rail to modify it to suit the MY rail.
Back section to grind off
Gound off piece installed back to liberty seat.
I was then able to mount the MY seat rail in the same way I did on the passenger seat. I then installed it into the MY wagon in the same way that I did on the passenger side.
Suspension lift.
subaruby
Post by subaruby » Tue Jun 22, 2010 9:20 pm
The other mods I needed to do were the plastic door step trims
Before
After
I also had to trim a small piece of metal off the door side of the passenger seat, and some plastic trim on the seat as it was catching as you slide the seat back
Before
After
Installed
Suspension lift.
Venom
Post by Venom » Tue Jun 22, 2010 9:59 pm
Nice work! Familiar looking seats too ;)
What did you fit into the Gen2?
Rhys
Post by AlpineRaven » Tue Jun 22, 2010 10:34 pm
they are comfortable seats, i have the same trim as yours in my 96 liberty.
The seats looks wider than MY is that right? or just the rails?
Post by El_Freddo » Wed Jun 23, 2010 8:37 am
Good work Richard. You know you should've palmed them off to me though :twisted:
I'm starting to regret not grabbing the seats outta that foz at centre road wreckers - they came with a gucci little arm rest too. I love those things and would LOVE to have a much more comfortable front seat as you do now Richard!
Baz's seat with lumber support isn't much better - it was for 5 minutes though!
Damn foz seats, the just seamed like too much effort at the time :(
Good stuff Subaruby, can't wait to sit in it... Now that you have an "EJ part" in your subi, when's the real EJ conversion coming???
Post by guyph_01 » Wed Jun 23, 2010 10:44 am
Great work, I love this thread. this will be very helpful. Would you have more pics of the driver side set-up? did you end up keeping the height adjustment feature?
vincentvega
Post by vincentvega » Wed Jun 23, 2010 7:15 pm
I have a GT foz pilot seat in my lib. the armrest is great for long drives, bu the seats do sit very high. I doubt they would fit well in an L
1111giles
Post by 1111giles » Wed Jun 23, 2010 8:13 pm
Foz seats in my MV / Brumby (piccys on the 'brumby front cut' thread).
Yes they sit maybe 15 - 20mm higher than original Brumby seats but seems to improve driving position for me. (I am 5' 10'')
Arm rest is a major bonus ( somtimes I spread my arm across both of them!)
Didn't have to loose the sill cover/tray thingy with my mount, just a small 'can't see it' nick in the tray to get the seat/rail support in the right place.
Used the original brumby seat floor fixings.
Deffo worth the effort can email images of my mount to anyone if thats a help.
Just ask.
Giles.
subaruby
Post by subaruby » Wed Jun 23, 2010 8:35 pm
Some impreza seats that I thought would fit in the "my" wagon, but did not fit and would have required work with a welder which I dont have.
So I thought I would try them in the liberty and they were a straight bolt in
Yep seats are definitely wider but still fit ok. just a little tight on the passenger seat near the seatbelt retractor
no ej, still have to hit 300k at least, next step some new tyres
Forester seats would definitely require more work to fit.
Dont really have any other pics, the liberty seat rails come off with 4 bolts. Once the rails were off I then had to grind off the bracket from the seat rail. It then just bolted the bracket back to the liberty seat.
I could then just bolt the "my" rails to the seat, only needing to re drill 2 new holes.
By doing this I did manage to keep the height adjustment
Suspension lift.
Point
Post by Point » Wed Jun 23, 2010 8:39 pm
I have G1 Lib seats in my brumby, but the seatback is a bit too thick to get the seat back far enough for me (I'm 6' 2"), so i'll have to try the spare Foz seats i have.
The lib seats required cutting on the drivers with the height adjust, and adapter plates to get the rails the right distance apart. I also had to trim the side plastic so it would slide.
98 Forester GX
02 Forester XS Luxury
Post by steptoe » Wed Jun 23, 2010 11:19 pm
Good spot to say do not follow me down the MAZ626 seats path. They are a lot of work to remove the wider sliders. The seat belt stalk fixes to seat rather than floor so seat sides are more robust again. Spent a few hours grinding and drilling out rivets and adjuster bump stops today to remove both rails from the last seat.
vsspack
Post by vsspack » Mon Jun 24, 2013 1:46 pm
Is the MY wagon floor pan the same as the brumbys? Would be nice to get seats that dont need welding to fit :)
vsspack
Post by vsspack » Mon Jun 24, 2013 2:31 pm
assuming they are but thought id check :)
Post by El_Freddo » Mon Jun 24, 2013 6:33 pm
vsspack wrote:Is the MY wagon floor pan the same as the brumbys? Would be nice to get seats that dont need welding to fit :)
Yes they are ;) But the brumby is different to the L series - some people get this confused at times as the brumby "MY chassis" ran up until '92.
vsspack
Post by vsspack » Fri Jun 28, 2013 11:08 am
Alright awesome because the seats in my brumby have collapsed springs and id like to replace them without needing to weld haha.
