to ALL MY and L Series owners
Do yourselves a favour and check your fusible links (follow POS battery terminal to black cover box plastic MY, brown for L) in the next coupla days. You could save a heck of a lot of grief in near future if you do. My BRumby had disabling symptoms at the age of 23 due to a FL that had corroded away where the female spade terminal goes from flat to the crimp section. It took a lot of wrong diagnostics by me to find it. Now it is my 23 year old GLTA - same thing- main FL just broken not burnt but seems to be the cause of my voltage spike or surge that has some expensive car and equipment damage and taking a while to find and fix what damage it has done, until then I can't drive it.
Come back in here and tell me you done it and what you found.
Jonno
Jonno
- openflame06
I can second this, I put a battery in the wrong way (stupid i know)
Turns out that whoever did the fusible links last time didnt put in the correct load link for the battery - running 1.25 or something instead of the black 2.25 i think it is link.
The links perish away easily when cars are 20 + years old and cause all sorts of problems.
If you hunt around at the wreckers or super cheap auto you can replace this fusible links with a bif fuse. It is kind of hard to explain but it has spade bits that fit perfectly in the original fuse holder. Takes car of the problem for good.
Added bonus you can look through the top and see if they are blown.
"Claudia"
"Claudia"
I have got a sample of the more modern fusible link, the coloured plastic box with a clear top enclosing the link female terminal , not the male terminal ones. . Going by colours, black to match the black original FL, I am not sure if the ratings are correctly matched. The manuals only seem to state 1.25mm cross section diameter of the wire for the black - no AMP rating, yet the new style box is rated at 80A 32V. Thought 80A was a bit high - that's landcruser glow plug rating!
Also wondering if 32V rating means that at 12V the 80A rating changes too like going too high?
answer is it is OK to use 32V in 12V applications looks like Amps stay the same
http://www.circuitprotection.ca/fuseology.html
- TOONGA
I was at the wreckers the other day and a 1983 sports wagon had a very interesting set of fusable links 2 ford 30 amp fuses and a 60 amp fuse for the engine side of things ( I would say)steptoe wrote:I have got a sample of the more modern fusible link, the coloured plastic box with a clear top enclosing the link female terminal , not the male terminal ones. . Going by colours, black to match the black original FL, I am not sure if the ratings are correctly matched. The manuals only seem to state 1.25mm cross section diameter of the wire for the black - no AMP rating, yet the new style box is rated at 80A 32V. Thought 80A was a bit high - that's landcruser glow plug rating!
I was having issues with my links and Ive tried this fix I was worried that 60 amps was too high but after reading this post it seems they will be ok (I have a 40 amp fuse for the engine Im going to try when the rain stops)
i've had trouble lately with corrosion of the fusible link connections causing them to get hot and melt.
spoke to an auto sparky about what i could use to replace that whole fl box, and he suggested circuit breakers, but that was going to be obscenely expensive, so i'm sticking with the newer plastic-cased sort of fls that plug straight in. Narva 53030 and 53060,and new terminals and better wiring to them.
Btw, the fuses section of the narva book says what the current ratings of the old different coloured fl wires are.
Dane.
Dane.
- Green_eyed_liberty
Yeah we have a similar problem in the red brumby. regularly blowing fuses. I'd be keen on the circuit breaker system and would love more explanation:)
- T'subaru
Heres an idea for you Toonga, ive bought circuit breakers for as little as 5.00 in an automatic, resetable tends to cost more, and there avail in several different brands, heres an exampleTOONGA wrote:Alex could you give me a link to these circuit breakers as that was my other choice but the ones Ive found must be 22 karat gold as they want 80 bucks a breaker and when you times that by 3 wifey says no
http://www.colehersee.com/catalog_top/index.htm
any large electrical house or parts store should have
Here is a link to a fusable link wire colour chart with specs
http://www.narva.com.au/products/browse/fuse-link-wire
It is a start to understanding but need a direct conversion to be sure
http://www.narva.com.au/products/browse/metal-manual
metal manual resettables
thanks to great webiste at Narva !
You should be able to get them cheaper directly from Ashdown-Ingrams.
You can find the closest branch here:
http://www.ashdown-ingram.com.au/contactus.html
- phillatdarwin
