Newbie in Philippines
oldbaz
Post by oldbaz » Thu Aug 12, 2010 11:38 am
Hi everybody! I'm a new member with my first Subaru (Legacy/Liberty BG5).
I live in an undeveloped part of the Philippines (Palawan), and had originally planned on buying a regular 4WD but was tempted to the Subaru as it is a one owner car, supplied by Subaru Philippines, well looked after, and with 87K on the clock. (Cars are expensive here, I got this one at a good price - AUD 6750).
Because of the state of the roads here I need a lift. Having read through these forums, I thought I'd go for a simple change to OB struts, so I asked Subaru Philippines for price and availability of OB struts to fit to my car.
The reply was - "FYI, Outback suspension cannot be fitted to your legacy 1998.
Mounting on the shock tower is also different.
Best regards,
Mike Luyun
Senior Manager - Operations
Motor Image Pilipinas, Inc
187 EDSA Greenhills, San Juan City
Metro Manila 1503, Philippines "
What do you guys say?
Post by RSR 555 » Thu Aug 12, 2010 12:17 pm
I'd say that they have no idea of an Outback.. as the Outback is a BG Legacy with a factory body lift and taller struts.
And ofcourse the EJ25 engine :)
d_generate
Post by d_generate » Thu Aug 12, 2010 3:37 pm
I say you are the manager of operations at the main Subaru dealership in the Philippines and picked up a cheap trade in. Forester or outback fronts will fit, only difference on the rear mountings is between sedan and wagon, Outback will fit but you should change lateral arm mounts and all other lift points.
oldbaz
Post by oldbaz » Thu Aug 12, 2010 8:21 pm
No mate, I'm just a simple Pom who bought the car in Manila!
Just need to know if I can go ahead and buy the Outback struts from Aus or US.
Post by RSR 555 » Thu Aug 12, 2010 8:58 pm
You would be best to find someone dismantling an Outback and grab parts from that.. like Tom said.. make sure you get the lateral rear arms and all the necessary raised items (i.e. engine x-member extensions, steering extension, etc..) and you should be fine. I haven't seen anyone over here in the west stripping one or I'd offer to help :( New KYB struts and Lovell Springs are available over here from W.A. Suspension. I'd use these and use your original strut tops and you'll be fine :)
oldbaz
Post by oldbaz » Fri Aug 13, 2010 12:01 pm
Thanks for the replies so far. I'm going to be out of internet coverage for a couple of days, so I'll catch up on Monday.
tex
Post by tex » Mon Aug 16, 2010 5:22 pm
I have a 96 outback so if need be I can make a list of the spacers on my factory one before I put my lift kit in!
87 targa brumby (Neglected),
+ others.
oldbaz
Post by oldbaz » Tue Aug 17, 2010 6:26 pm
ThanksTex,
Asyoucansee,Ihaveaproblematthemoment!
I'll,separate,like,this,
From,another,Forum,I,got,the,impression,that,a,simple,inch,and,a,half,lift,could,be,achieved,by,simply,replacing,the,Legacy,struts,with,Outback,,Guess,I,was,wrong,,,,
