making a engine run.
- yellowsubie
how do you make an engine run when its not in a car ? as i have bought a subaru engine to play around with. i have made a frame up to put the engine into.
any help would be greatly apppectaite
- last celtic warrior
- sven '2'
+ ear muffs and a video camera to catch it rattling about your shed floor knocking over the fuel can whilst 4 blokes who are old enough know better not to do this at 2am with just a few lemonades on board run for the door...
First of all, what type of engine? EA81, EA82, EJ22, EJ20 Turbo?
All engines need fuel, air and electricity.
Assuming its an EA81 or EA82 with a carburettor'd engine
So you will need a fuel container, a pump and some fuel hose.
Does it have any sort of wiring loom with it? Because you will need 12v to the anti-dieseling solenoid, the ignition coil, the distributor ect.
How mechanical are you?
- yellowsubie
You will need to connect power to the coil and dizzy, and have a wire to the start solenoid to get the thing cranking over. To mount the starter you'll need either some sort of frame to hold the starter in the right spot to make it work or mount a gearbox to the engine. You could add a frame to the engine to support it.
This is how I did my EJ test run on the shed floor:
http://www.youtube.com/watch?v=CUjKbPrZDLM
If it's a Carby EA82 then you'll need..
1. Fuel supply via a low pressure facet pump
2. Power supply.. battery connected to a coil and the starter motor
If it's a EA82 EFI model then you'll need..
1. Fuel suppy via a high pressure pump
Both engines will need a flywheel and gearbox (with starter motor) to swing the engine over.
Here is Jules's EJ engine with a carby and dizzy started on the floor of my workshop
http://www.youtube.com/watch?v=PN3ZXTRESms
Lets also not forget cooling shall we? If the engine is going to run anywhere over 30 seconds you will also need a radiator hooked up with a strong fan blowing through it or running a cold water hose through an open radiator opening (with bottom cock open).
That as well..GTlegs wrote:Lets also not forget cooling shall we? If the engine is going to run anywhere over 30 seconds you will also need a radiator hooked up with a strong fan blowing through it or running a cold water hose through an open radiator opening (with bottom cock open).
Also a good ventilation in your workshop as well, unless you wanna commit suicide!
http://www.youtube.com/watch?v=M0FSjuXRIMw
Fuel supply and return if it is a return type carby.
Coil, disty wiring, fuel cut solenoid power on carby.
At least the y-pipe on the exhaust is a good idea.
Gearbox to mount starter motor on. Or as I have, a piece of gearbox cut off to bolt the starter motor onto.
Depending on engine type and age all the vacuum operated accessories should be plugged on. If not the engine won't run quite right and it will bother you. Also vac leaks like the break booster need to be plugged!
