Subaru EJ in VW 1303S
I intend to fit a Subaru Ej engine into my VW.
I have 2 options.
1. A Subaru Imreza Subaru Impreza 1.8 GL 4X4 -94
Chassie number GF6BLOEJ021804
OR
2. Subaru Legacy Estate 2.0 4WD -92
Question: What is the difference between this two motors concerning
fitting it to my VW gearbox?
Can I use the same Kennedy adapter for the two motors or...?
Can I use spareparts between the two engines?
Thanks for help.
New Subaru fan / Erik
I have 2 options.
OR
Thanks for help.
Both motors are almost identical, except for their capacity.
There may be a few electrical differences too
Go the 2.0, more power and most likely will be Multi Point fuel injected.
The 1.8 might be single point fuel injected
- d_generate
2L Legacy motor will more than likely be a quad cam unit, mine was (JDM) and punch out a lot more power, both have similar fuel injection & you'll need to run the computer.
both will go just fine with the kennedyh adaptor.
hope u got a heavier clutch as the standard vw clutch will shit itself pretty quick.
davo
davo
Its Sweden, not Japan, so i doubt the NA EJ20 will be DOHC
Have you got pictures of each engine?
- phillatdarwin
hope u are going to put a good custom gear box for it .as it will not last long
there was one in darwin not long ago but the custom box out of a vw big brother sports car and blow it to pieces $$$ cost price now $5,000 to rebuild it .
i think it had a late WRX engine in it .was making big hp on boost
- phillatdarwin
heh...ive broken numerous transmitions weith my shitty na ej engine...ahaha...hopefully the latest one lasts a while, 6rib 2litre kombi box, with an albeins super diff... better last...cost enough..haha
davo
davo
Dad's run a 13B rotary infront of a VW gearbox without any issues - that was in his rally car quite a few years ago now.
I've also seen a kermit green kombi that features a 3.9 litre holden V6 running behind a version 3 gearbox - the stronger of the factory boxes. AFAIK its going well without any issues - can't remember the website though I'm sorry.
How the feck are you breaking kombi boxes with an N/A ?D3V1L wrote:heh...ive broken numerous transmitions weith my shitty na ej engine...ahaha...hopefully the latest one lasts a while, 6rib 2litre kombi box, with an albeins super diff... better last...cost enough..haha
davo
I've got 2 mates running EJ20T behind stock bug boxes
one went for 2 years before breaking the other is still going, both cars are regularly down the strip
Like Bennie my 13B rota bug went for 13 years too with no breakages,
