carby help
shazdave67
carby help
Post by shazdave67 » Sun Dec 05, 2010 12:15 pm
Hi fellas, i pulled my carby apart today and 2 ball bearins and another thing came out when i tipped it upsie down, i know one of them goes in the plunger and i think the weight does to but not sure about the other ball.. Cant find help on net anywhere,, help please.. Dave
Post by TOONGA » Sun Dec 05, 2010 12:35 pm
shazdave67 welcome to the board acouple of questions about the carby
1. what type of carby is it?
2 do you have the carby kit for it? as it should have a diagram of where all the parts go
littlewhiteute
Post by littlewhiteute » Sun Dec 05, 2010 12:44 pm
Dave,
I'll take a educated guess, all to do with accelerator pump circuit.
One ball bearing and weight is the "outlet check valve", other ball bearing is the "inlet check valve" at the base of the pump well under the spring.
One end of the spring is made to retain the ball in the base of the pump well.
Gary ;)
shazdave67
Post by shazdave67 » Fri Dec 10, 2010 11:33 am
Thanks boys couldent find the thread only new,, think ive got it sorted but im sure they have the wrong spring in the acc, pump? The weight has no place for it to sit in it if you know what i mean? And one ball is bigger then the other, so what one goes where? Have a carby kit but it dont show the weight or the balls..
Post by TOONGA » Fri Dec 10, 2010 2:42 pm
still need to know what car it came off :) and what make carby it is otherwise Im just guessing
shazdave67
Post by shazdave67 » Fri Dec 10, 2010 4:19 pm
its off an 85 gl leone front wheel drive, ea82? manual choke, 5 spd. cant find a diagram any where on net,,
