2" Brumby Lift: brake lines?
Green_eyed_liberty
Post by Green_eyed_liberty » Mon May 09, 2011 4:52 pm
hey guys, just installed a 2" body lift on my Brumby.. and the brake lines have me worried.
they seem to be at full extension. i dont think normal driving would be an issue.. but off road with a bit of flex might have dramas.
is there any easy way to fix the drama. (ie. L series/Forester brake lines are longer?)
or do i need to get custom ones made up?
surely many people would have had this problem.
cheers for any input
Tony
Post by steptoe » Mon May 09, 2011 7:27 pm
get them off and take/send to a brake joint to make newies but just 2" longer
phil nelis
re;brake lines
Post by phil nelis » Mon May 09, 2011 8:09 pm
As steptoe said,just remove and get longer ones made.shouldn`t cost more than 30 bucks for all four,i had mine done,took the guy about ten minutes.
Post by steptoe » Mon May 09, 2011 11:15 pm
More approx cost for me was $20 each , ca$h :)
ashleyn
Post by ashleyn » Fri Jul 01, 2011 9:57 am
Green_eyed_liberty wrote:hey guys, just installed a 2" body lift on my Brumby.. and the brake lines have me worried.
Tony
I'm about to fit a kit to my Brumby, and tips, tricks or gotcha's I need to know about ?
Green_eyed_liberty
Post by Green_eyed_liberty » Fri Jul 01, 2011 6:25 pm
didnt you PM me about this a while back?
still have more questions? :-)
ashleyn
Post by ashleyn » Sat Jul 02, 2011 7:37 pm
Green_eyed_liberty wrote:didnt you PM me about this a while back?
Might have. Just trying to get as much info as possible. I've started the job and finding removing the bolts to be really hard. Using a 450mm breaker bar, do I need bigger to make it easier ?
Green_eyed_liberty
Post by Green_eyed_liberty » Sat Jul 02, 2011 7:55 pm
i used a RattleGun/ Compressor,
all good man, if you get stuck on something post up. im sure theres plenty of help here
ashleyn
Post by ashleyn » Sun Jul 03, 2011 7:13 pm
Green_eyed_liberty wrote:i used a RattleGun/ Compressor,
Great info, Rattle gun from Kenards saved the day, got the rear done. Bit stuck on removing the struts, Gregorys is a bit vague and it doesn't seem to be that obvious (well to me anyway). Any tips anyone ?
eg it says "remove the suspension unit clamp bolt and the bracket retaining bolt" but no pics showing what/where these are.
