In need of advice !!!
Kenny_G
Post by Kenny_G » Fri Jul 15, 2011 6:59 pm
Hi all,
I have a 92 model Brumby & i am wanting to put another engine in her. I'm having a hard time in deciding what way to go. ej20 or ej22 ????? Which one would be better and which one is more hassle ? If anyone has any suggestions on what way they think i should go PLEASE reply as i am doing my head in :confused:. Looking forward to hearing all your thought's. CHEERS
niterida
Post by niterida » Fri Jul 15, 2011 7:15 pm
I had the same dilemna so decided on an EJ20 in the front and an EJ22 in the back - both Turbo of course :-)
Post by steptoe » Fri Jul 15, 2011 7:39 pm
If it helps, I know a fella that went EJ20G (turbo) and AWD RS lib manual box, spent a motza with front suspension and rear disc brakes and ended up pulling the turbo engine out and settled for plain jane EJ20. His realistic travel times really did not change due observing speed limits both engines, had fewer worries with his staff using it for work etc.
Bein in NSW it will be easier to convince authorities you have kept within the 15% increase in capacity for owner certified modifications. EJ22 falls outide that 15%
Post by El_Freddo » Sat Jul 16, 2011 5:59 am
I've got the EJ22 in Ruby Scoo. I mainly went this way for two reasons: 1) it's a tried and tested combination in the L and 2) they were readily available in the yards when I started gathering parts. Now I'm seeing the odd EJ20 in the yard.
I'd have a guess that the wiring for both engines will basically be the same so there shouldn't be any extra difficulty in cutting the EJ20 loom down.
Also remember that the newer the engine and management system, the more complicated the cut down can become due to new sensors/ECU technology/immobilisers etc.
