Brumby Head Lights Dull
Does anyone have an electrical schematic diagram for a 1991 Brumby with Quad headlights? I have a Gregory's workshop manual with wiring diagrams but i can't work out how the circuit works from that?
The problem is the right hand lights are extremely dull to the point you have to look at them closely to see if they are on. The left hand lights work as usual. My driving lights do no work and the high beam indicator on the dash doesn't light up when they are on but the left hand high beams work fine. So i think maybe there is a high resistance joint somewhere under the dash and there isn't enough juice to close the driving light relay as it is tapped off one of the head lights. Can anyone help? Thanks.
- Subarubrumbyfan1991
- TOONGA
check your fusable links as well the little buggers look fine, but after 20 + years they are sick of having current passed through them.
a little read for you
showthread.php?t=18205&highlight=fusable+links
+1.. I had this a few times in various subies.silusboy wrote:First of all check all connections in the engine bay area, as it sounds like you have a bad earth around or near the headlights, Quite common fault.
Hope that helps
Also look at replacing your sealed beams with H4s and H1s.. these will need rewiring but you'll never regret it.
Ok, so it was a blown fuse
. But they didn't charge me anything to fix it and they got the Air Conditioner going so i'm very happy.
RSR, what are H4 and H1's? I was reading that 80 series landcruiser lights fit perfectly so i was going to use them. I was going to run a new circuit off the battery and use the current wiring loom at the lights to run the relay for the new lights as an easy fix? Sound good/bad? Cause the current lights are still shockingly bad! I think the parkers on most other cars are better then my high beam:(
- Green_eyed_liberty
H4s and H1s are the types of globes used in the lenses. The factory ones are seal beams so you can't change the globe as such. If you buy the LC ones, they'll work great but you'll need to swap the wiring around a bit. I'd recommend you get them rewired with thicker wires and relays, that way you'll get to fit globes like 55/100W in them and man.. you'll be stoked555Ron wrote:Ok, so it was a blown fuse. But they didn't charge me anything to fix it and they got the Air Conditioner going so i'm very happy.
