Hey guys,
just need to know whether an ea82 from an auto can be bolted up to a manual gearbox and what needs to be done. I had a search around and i read something about the spigot bearing needing something done, still not quite sure what it needs.
Sagey
Ea82 manual/auto help
- TOONGA
I presume it is a manual car the motor is going into you don't just need a spigot bearing you need a flywheel as well. Just take the flex plate of the engine from the Auto donor and put the flywheel on. as long as you have the clutch and pressure plate and other bits it will all be plug and play.
