Dann's 92 Subaru L Series Build
Post by guyph_01 » Sun Nov 06, 2011 3:21 pm
hose to hose, Just connect this to the hose that goes in the body and get rid of everything else.
Works fine for me:)
Post by El_Freddo » Sun Nov 06, 2011 7:43 pm
Dann wrote:And just wondering what is this and what is it for, do I need it??
WTF by Dann_Evans, on Flickr
The tank is the vacuum canister, good to keep as this is how your climate controls worked from factory.
The wires and relays below are for the AC - the one with the vacuum hose can be closed off and looped around on itself as the EJ won't need it once/if you get the AC connected and gassed up. I've not got my AC connected but I would like to have it, just money holds me back.
Dann
Post by Dann » Sun Nov 06, 2011 11:04 pm
El_Freddo wrote:The tank is the vacuum canister, good to keep as this is how your climate controls worked from factory.
True True, yeah i'll have a look,
Another question what is this pipe for?? Do I need it?? if so where do I attach it??vvvv
IMG_3464 by Dann_Evans, on Flickr
The update for today is just finishing off the little bits and bobs, like connecting all the hoses to the engine, heater, fuel, accelerator, etc, put the radiator in, lined up the power steering knuckle to get welded tomoz, cleaned up some wiring, heres a pic of the progress so far.
All thats got to be done now is, bend and weld the liberty exhuast on, fit the steering knuckle, and then the long wiat til the weekend for Dave(subarino) to work his magic on my wiring, then fire in the hall :P
IMG_3466 by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
Wagonman
Post by Wagonman » Sun Nov 06, 2011 11:48 pm
They went with out that back in the old days.. so she'll be right ;) Nah bro thats your brake booster vacuum connection. you defs wanna be putting that on. I found the standard ea brake booster vac hose reached just fine.. the ej one is in a very similar position.
Dann
Post by Dann » Sun Nov 06, 2011 11:52 pm
Wagonman wrote:They went with out that back in the old days.. so she'll be right ;) Nah bro thats your brake booster vacuum connection. you defs wanna be putting that on. I found the standard ea brake booster vac hose reached just fine.. the ej one is in a very similar position.
oh ok... Wait you guys have brakes?? :???:
haha yeah I'll have a fiddle around tomoz with that.
Dann
Looking for:
- LSD diff
d_generate
Post by d_generate » Mon Nov 07, 2011 12:14 am
Going great mate, can't wait till we all get out there again, you'll be flying up that triple track hill at Two Rocks.
Post by El_Freddo » Mon Nov 07, 2011 1:05 pm
Dann wrote:Image
Looking good mate! Will you be connecting up your AC? It's something I want to do, but I've got a few things to do to Ruby Scoo before hand, plus I've not got the money to have the pipes made up and have the system gassed.
Post by NachaLuva » Mon Nov 07, 2011 4:21 pm
Looking good. Hope all the fiddly bits go well...
Post by Alex » Mon Nov 07, 2011 4:49 pm
very neat mate good work.
ps i like how close the pulley shrouds are to the radiator!
Dann
Post by Dann » Wed Nov 09, 2011 7:54 pm
d_generate wrote:Going great mate, can't wait till we all get out there again, you'll be flying up that triple track hill at Two Rocks.
Tom those tracks are flat now the last time I when lol,
El_Freddo wrote:Looking good mate! Will you be connecting up your AC? It's something I want to do, but I've got a few things to do to Ruby Scoo before hand, plus I've not got the money to have the pipes made up and have the system gassed.
Yes I'll defiantly be connecting up my aircon, summer gets quiet hot, :) i'm thinking the way pauls doing his is the way to go, i'll probs talk to him bout that
nachaluva wrote:Looking good. Hope all the fiddly bits go well...
Thanks mate down to the last bits now and finding little annoying things that are setting me back... hope I can get everything done before sunday so dave can wire it up
Alex wrote:very neat mate good work.
cheers, and yeah does look pretty close in the pic, but theres about an inch gap by the pulley shrouds and bout slightly more than a 2 inch gap else where.
Dann
Looking for:
- LSD diff
Dann
Post by Dann » Wed Nov 09, 2011 9:23 pm
alright another little question can I run the car without the aircon hoses attached, or do I need them on?? cause it will be alittle bit before I can sort out the hose adapter,
Also can someone please post up a pic of where and what the hose looks like for the brake booster cause i'm confused, Thanks
Dann
Looking for:
- LSD diff
Post by TOONGA » Wed Nov 09, 2011 9:37 pm
Dann this is on my brumby, but it is in the exact same spot on the liberty and "L" series motor. just make sure the one way valve is hooked up the right way.
In the picture it is the hose that runs above the brake reservoir across to the manifold near the two bolt holes.
as for the aircon you don't need it hooked up to run the car mine isn't in Jetcar. (eventually it will be) just make sure all the hose ends are sealed and taped securely.
Dann
Post by Dann » Wed Nov 09, 2011 9:54 pm
thanks jules, so just confirming the hose is there for what?? is it just a vaccum hose for the booster or something else,
Dann
Looking for:
- LSD diff
Post by TOONGA » Wed Nov 09, 2011 10:43 pm
Yep it creates vacuum for the booster so your brakes work easier, with out the booster you must use more force.
You should have the line still from the "L" series motor just put that back on and happy braking
Dann
Post by Dann » Wed Nov 09, 2011 10:46 pm
hahah yeah I just had another look and found it under the engine cover, and yes I took the hose off the ea82 but it's cracked so i'll pop off to the shops tomorrow and get it along with lots of other little last minute things.
Dann
Looking for:
- LSD diff
Post by guyph_01 » Wed Nov 09, 2011 11:48 pm
don't forget the one way valve in the hose...
SuBaRiNo
Post by SuBaRiNo » Thu Nov 10, 2011 10:35 pm
looking really good there mate... just about to send u a PM about the weekend now.
Dave
Post by guyph_01 » Fri Nov 11, 2011 12:25 am
For a little extra$$ Dave should wire the fans on relays for you..., So fans have plenty of power and don't let the engine get hot:)
Just my 2cent worth..
SuBaRiNo
Post by SuBaRiNo » Fri Nov 11, 2011 7:17 pm
LOL i just said that to him in the PM i sent him Guy... lol... obviously an optional extra.
Dave
Dann
Post by Dann » Sun Nov 13, 2011 11:38 pm
Ok so a nice early start today,
Dave arrived and worked his magic with the wiring loom,
all went well besides for afew little things like one fan wasn't working properly so I got it swapped for another one.
But the main thing is that it's running :) Started first go, so happy
now just putting all the fenders on and tiding up so wiring,
Only Thing left to do now is sort the engine mounts out, they are original mounts so the bolt with the wedge is to short for the nut the hold nicely on so I'm thinking i'm going to get after market mounts cause everyone is saying that they have a longer bolt, Please can someone confirm this?? and if so where to I get them from, I know it's a dealer thing But which one? has anyone got them recently??
Other than that she purrs like a kitten, love it
Thanks to Everyone who has helped along the way and give moral support, Really appreciate it,
Heres the final pic of the engine bay with everything done,
EJ22 finished by Dann_Evans, on Flickr
Dann
Looking for:
- LSD diff
