Brumby build with a difference
wrxer
Post by wrxer » Wed Nov 16, 2011 11:47 pm
man, thats awesome what you have done to the old brumby, with the floor out it must be tempting to channel it a couple of inches.
i will be in geraldton over xmas, maybe i can have a look in the flesh and share a beer or 2.
i cant believe the effort you have thrown at this car. truly inspiring. awesome work
"UNDERSTEER" is when you hit the fence with the front of the car.
"OVERSTEER" is when you hit the fence with the rear of the car.
"HORSEPOWER" is how fast you hit the fence.
"TORQUE" is how far you take the fence with you.
If it works, pull it apart to see why.
niterida
Post by niterida » Thu Nov 17, 2011 12:03 am
wrxer wrote:man, thats awesome what you have done to the old brumby, with the floor out it must be tempting to channel it a couple of inches.
mmmmm channelling hey ????? Nah that would be too much work......
although it would be nice - even with this way of doing the conversion its not going to sit as low as I wanted it :(
hmmmmm beeeeeeer :D
Oh hang on I don't drink beer :confused: make it a bourbon or 12 :twisted:
niterida
Post by niterida » Thu Nov 17, 2011 6:42 pm
Came across my first problem :(
The chassis rails were pushed out wider than I thought and this has left a little bit of a gaping hole :
But not to worry - 3 hours playing with cardboard and then some decent 1.6mm steel resulted in this :
Should be plenty storng enough and still looks like a factory stamping (or at least it will once its welded in and all the gaps filled and smoothed.
Pretty stoked with that as it is my first attempt at something like this :)
Post by RSR 555 » Fri Nov 18, 2011 10:13 am
Awesome work there Ken.. can't wait to see it in the flesh :mrgreen:
wrxer
Post by wrxer » Fri Nov 18, 2011 10:30 pm
im not sure how you are drilling spot welds, but i use one of these:
http://www.ebay.com.au/itm/HSS-3-8-10mm ... 519bc52c91
well worth the money. i use it with the cordless drill so you can slow it right and use plenty of pressure. it easy to just cut the top layer of steel, leaving a button of spot weld on the rear sheet.
i have a snapon drill as well like this:
http://www.ebay.com.au/itm/3Pce-6mm-8mm ... 3f0ffd5557
but because it drills the weld hardened area, it goes blunt quick. the top one is pretty good and is still sharp after the 70 odd spots i have removed.
btw, how are you keeping everything aligned and positioned? plumb bob and tape measure? the alignment thing boggles me
niterida
Post by niterida » Fri Nov 18, 2011 10:40 pm
wrxer wrote:im not sure how you are drilling spot welds, but i use one of these:
Yeah got both of those types of cutter - prefer the drill bit type,
Aligned and positioned ? Hadn't even thought about - just putting it back where it looks right - hahahahaha
But seriously the frame rails are positioned by the Crossmember, LCA and gearbox mount - just made sure it was square once it was all bolted in tight. Then just need to make sure it the whole assembly is then square once its on the body. Probably won't be perfect but should be within a few mm.
niterida
Post by niterida » Mon Dec 19, 2011 5:27 pm
Small update :
Been trying to get that bracket from the chassis to the firewall perfect. Done about a dozen attempts in cardboard and half a dozen in steel and just can't quite get the shape and fit right. Even went to the trouble of filling the space with expanding foam and trimming that to exactly the right shape and I still can't replicate it in steel :(
1. Fill hole with foam :
2. Move chassis rail out of the way :
3. Cut away excess foam :
4. Final shape - guaranteed to be correct :
And on a positive note my engineer came over and gave me the big thumbs up for the work so far :)
niterida
Post by niterida » Mon Dec 19, 2011 10:22 pm
Spent the afternoon today transferring the foam shape into metal and finally got it right - YAY !! Photos tomorrow.......
niterida
Post by niterida » Tue Dec 20, 2011 9:02 pm
BOOOOOO !!!!
No pics yet cos I still didn't get it right - bloody compound curves grrrrrrr.
I think I've got it nailed now but back at work for the next week so won't be able to do any more till then. This has taken me about 60hours so far - ouch !!
Post by RSR 555 » Thu Dec 22, 2011 4:26 pm
Yeah.. looks like you're on a winner there Ken :cool:
niterida
Post by niterida » Thu Dec 22, 2011 4:32 pm
OI thats enough sarcasm in my thread thank you very much..............
Post by RSR 555 » Thu Dec 22, 2011 5:35 pm
niterida wrote:OI thats enough sarcasm in my thread thank you very much..............
What?? sarcasm.. me?? come on Ken, you know that's not I :rolleyes:
But seriously.. I think that could work
Post by NachaLuva » Thu Dec 22, 2011 9:04 pm
niterida wrote:BOOOOOO !!!!
Could you do it in fibreglass so it holds its shape better? A couple of layers of chop over the foam should work...maybe?
niterida
Post by niterida » Thu Dec 22, 2011 10:01 pm
nachaluva wrote:Could you do it in fibreglass so it holds its shape better? A couple of layers of chop over the foam should work...maybe?
Its not the foam thats the problem. Because it bends in 3 or 4 different ways if you are a mm out with the angle or the size it completely throws it out of shape when done in steel. But I'm pretty sure I've got the template right now so tomorrow I may get time to have another crack at it.
Of course I could have made it easy on myself by doing it outof 2 or 3 different pices and just doing flat bends and welding it together with straight lines, but then it wouldn't look factory and wouldn't be half as much fun :twisted:
niterida
Post by niterida » Mon Dec 26, 2011 6:08 pm
SUCCESS !!!!!!
What a bloody nightmare this has been getting one piddly little bracket made.
Now I have to make a template from this one and then make 2 proper ones - the one in the photo looks good but it is missing a couple of bits where you can't see it - the joys of trying to amke things fit.
So tomorrows job is to make 2 good ones and then hopefully Wednesday I will be able to tack weld them in place, tack the chassis rails on and then tack the Liberty floor in as well.
Then I have to find someone with real welding skills to weld everything in properly. But it will be all smooth fast sailing once this bit of the project is done. Downhill from here...........
Post by El_Freddo » Tue Dec 27, 2011 9:24 am
niterida wrote:And on a positive note my engineer came over and gave me the big thumbs up for the work so far :)
That's great news mate! You must be stoked!!
niterida wrote:Then I have to find someone with real welding skills to weld everything in properly. But it will be all smooth fast sailing once this bit of the project is done. Downhill from here...........
Don't be going too fast now niterida - you want to make sure you've done it all properly so it is sweet as possible! It's all ready a sweet project, but I think the aim as been to go for "sweet az bro" status ;)
Post by steptoe » Tue Dec 27, 2011 10:56 am
lookin' pretty good :)
Post by RSR 555 » Tue Dec 27, 2011 11:28 am
I could weld for you Ken but bit hard when you're in Gero :( unless you know of a good welding machine up your way and put me up for a couple of days :mrgreen:
niterida
Post by niterida » Tue Dec 27, 2011 11:40 am
RSR 555 wrote:I could weld for you Ken but bit hard when you're in Gero :( unless you know of a good welding machine up your way and put me up for a couple of days :mrgreen:
Thanks for the offer Paul but it needs to be done properly ;)
But seriously it does have to be done by a coded welder as they have to sign off on it for the engineering to be approved :(
Wouldn't want it falling apart in the middle of a 10sec 1/4 :)
Post by NachaLuva » Tue Dec 27, 2011 12:49 pm
Looks like a really good job you've done!
I agree with Scott, take your time & do it right..."measure twice & cut once" :mrgreen:
