Sale includes:
V4 STI gearbox, 4.44 ratio
Matching rear VLSD diff. No label on the diff, which is how it came in my car.
Complete hydraulic clutch setup including pedal, lines resevoir, slave cylinder etc.
Can include matching tailshaft if needed.
KMs unknown
You'll need to replace the nuetral and reverse switches. One front output shaft seal is leaking slightly. Syncros are all good and it shifts really well. Rear diff requires pre-98 LSD rear shafts.
Only replaced because i've put in a custom dual range setup.
$1400 for the lot, located in Eltham, VIC. Pick up only. Prefering to sell everything together.
Cash on pickup or after bank transfer has cleared.
Rhys
TXT or call me on 0409 006 559 because i'm not always on to check PMs.
