ea82t speed sensor
ea82t speed sensor
I have fitted an ea82t into my brumby, I was wondering if not using the speed sensor in the dash would cause any problems other than giving a fault code?
- SCOOBIDOO
i have an ea82t in another body,and it use,s the same fuel with or without the sensor...although i know for sure it stalls every 3 minutesdue to a fuel increase momentarily....if you have the engine idle up at 1200 it seems to pull thropugh by the time it drops to 750 or so once it initiates its glitch...
anyhow i have a speed sensor and am going to install it beside the magnetic bell spool on the speedo on the new car and this will give it the pulse it needs...by the way when the vehicle is not in motion..there is no reading...disconnected state...so you can still eliminate the speed sensor for any tuning probs you have as it is the same as being disconnected..when the vehicle is staionary..cheers
The speed sensor is designed to up the idle speed when the car is moving, supposed to create less stress for the clutch of something
- Fury
In addition, If you have air suspension or cruise control, it responds with lowering the suspension automatically after a given speed, and using the pulses for the speed control side of the cruise.Suparoo wrote:The speed sensor is designed to up the idle speed when the car is moving, supposed to create less stress for the clutch of something
Chris
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT!
