um what about the 12V to the coil instead of 8 or 9 that the points set up delivers through the thingamybob resistor in the ceramic doo dad?
What is the timing you got now you swapped ?
What Distributor Should I Have?
Yep
Mate, I took your advice, opened the front of my pants, all I found was this huge problem, or so the wife says!RSR 555 wrote:Not sure Ray.. open the front of your pants and check yourself
Only kidding mateyou can swap from Points to Electronic easily (harder the other way) all you need is to remove the points coil and resistor and wire the new electronic coil directly to 12v ignition positive and you'll need to swap the dizzy ofcourse.
Thanks for the data on the ballast resistor, I'll do the transplant over the next week or so
cheers
hahaha... stop dreamingWooster wrote:Mate, I took your advice, opened the front of my pants, all I found was this huge problem, or so the wife says!
cheers
Let us know how it goes.
Jonno.. yeah, he just needs to use the 12v that is at the coil (ignition switched) and if he uses the Electronic coil, it wont have the 8-9v coming out that doo-dad, as it wont be there
I do like your description of the ceramic resistor though
hahaha.. you live about 400kms too far south to be in paradiseWooster wrote:When one lives in Paradise , life is a dream mate
