Quick mods
ausbrumby
Quick mods
Post by ausbrumby » Tue Feb 14, 2012 3:11 pm
Just wondering if there is any quick and easy mods that I can do to my brumby?
Post by Alex » Tue Feb 14, 2012 3:18 pm
in what regard?
you could put new seat covers on? thats quick as easy
ausbrumby
Post by ausbrumby » Tue Feb 14, 2012 3:19 pm
Performance wise maybe?
Post by RSR 555 » Tue Feb 14, 2012 3:31 pm
Paint it red.. they always go faster :mrgreen:
Post by RSR 555 » Tue Feb 14, 2012 3:32 pm
Easiest upgrade is the Weber Carby Kit.. Ebay has the whole package deals on them :cool:
ausbrumby
Post by ausbrumby » Tue Feb 14, 2012 3:38 pm
Got red brakes :P and already got a weber carb kit :) I bought it for $4250, no rust really straight, good buy or what?
Post by RSR 555 » Tue Feb 14, 2012 3:53 pm
Looks like a fairly latest model (if it's the one in you avatar?) and next thing would be exhaust upgrade.
ausbrumby
Post by ausbrumby » Tue Feb 14, 2012 3:57 pm
How much for exhaust? And I'm getting a tonneau cover soon
Bungers
Post by Bungers » Tue Feb 14, 2012 4:34 pm
Tonneau cover equals 15 kw on dyno dynamics
Id gut the cat out of the exhaust.
ausbrumby
Post by ausbrumby » Tue Feb 14, 2012 4:41 pm
Does any one have an idea how much an exhaust will cost?
B00sting
Post by B00sting » Tue Feb 14, 2012 5:40 pm
You can buy the tonneau brand new for around 180-220 online. (not really a performance mod though haha).
An exhaust could cost you anywhere from 250-1000+, all depends on what you want/material/workshop.
Are you gearing this towards on road performance or off-road?
You could invest in some good rubber for starters.
-97 Landcruiser :D
ausbrumby
Post by ausbrumby » Tue Feb 14, 2012 5:54 pm
I'm going on road performance, yeah I got some good directional road tyres
revmax
Post by revmax » Tue Feb 14, 2012 5:59 pm
check and adjust valve clearances.
Disconect the belt for air con if air con fitted.
run 98 octane fuel
run some upper cyl cleaner through it.
adjust ignition timing untill pinging occurs then back it off till it stops pinging.
B00sting
Post by B00sting » Tue Feb 14, 2012 8:05 pm
DIY Cold Air Intake.
-97 Landcruiser :D
Post by El_Freddo » Tue Feb 14, 2012 8:06 pm
B00sting wrote:You can buy the tonneau brand new for around 180-220 online. (not really a performance mod though haha).
I'd take the brumby to you're local canvas joint and have them make a tonneau cover for it. It'll cost the same and will fit from the start, where as the online unit might not fit the tie down points and if you don't have a middle bar you'll need one of them too.
Post by steptoe » Tue Feb 14, 2012 9:18 pm
God point as Brumbies tend not to have same pattern for the studs at the window, nor same loop catch positions. I have one that was continuous length of bungey cord, another that has the neato loops. The first one allows much more leeway in fitting bulky things under tarp. My std exhaust is quiet and ute goes just as hard as my 2" zaust on the other. Would not class it as performance exhaust.
Save yer money, buy a spare dizzy ignition control module for your keyring - one thing that stoips a Brumby dead - had two so far.
Post by RSR 555 » Wed Feb 15, 2012 2:57 pm
yeah.. 2" zorst should be good :cool:
And the tonneau cover is bound to add HUGE power :mrgreen:
ausbrumby
Post by ausbrumby » Wed Feb 15, 2012 5:50 pm
Cheers for the help guys
subybrumby
Post by subybrumby » Wed Feb 15, 2012 5:57 pm
You can have my tonneau cover if you can find the bastard that stole it....and the chrome cross bar which they took too.
B00sting
Post by B00sting » Thu Feb 16, 2012 6:58 pm
El_Freddo wrote:I'd take the brumby to you're local canvas joint and have them make a tonneau cover for it. It'll cost the same and will fit from the start, where as the online unit might not fit the tie down points and if you don't have a middle bar you'll need one of them too.
all good points.
i bought mine online and it fit 100% but would be worth doing whats said above for sure. mine also came with a crossbar and the bar that mounts to rear window.
-97 Landcruiser :D
