L 1.6 low range into Â’97 Outback
MY_STI
L 1.6 low range into ’97 Outback
Post by MY_STI » Wed Mar 21, 2012 1:02 pm
Is it possible?
Have done a few EA lows into Gen1 DR lib boxes but never Gen2, Which I presume a ’97 Outback is? Pretty sure I’ve read somewhere a long time ago that the gen3 gearboxes can no longer take the L low but Gen2’s are still all good?
Just wanted to quickly double check before I strip down the gearbox and find out it can’t be made to fit.
Thanks,
Will
'97 Outback - almost back to grandma spec operating condition.
"A day is never more than what you make of it."
ScubyRoo
Post by ScubyRoo » Wed Mar 21, 2012 4:44 pm
The front half of the input shaft gearset on gen 2 boxes are different, particularly the synchro ring - look at AlpineRaven's big thread for all you need to know about 1.6 low range into gen 2 boxes.
Davidov
Post by Davidov » Wed Mar 21, 2012 10:13 pm
Deffinately possible as it has been done on similar gearboxes, however an easier option is dropping a 1st gen Forester low range in there. As far as i know it is a straight swap?
And the forester low range deffinately is more than capable enough considering the price and relative ease it can be done for.
taza
Post by taza » Wed Mar 21, 2012 10:16 pm
Davidov wrote:Deffinately possible as it has been done on similar gearboxes, however an easier option is dropping a 1st gen Forester low range in there. As far as i know it is a straight swap?
If the box is being rebuilt though it is just as cheap to put in L-Series low range. You can get an L-Series gearbox for $100 and getting the gear shaven down to fit is cheapish.
Post by guyph_01 » Thu Mar 22, 2012 12:01 am
I've got an L series box good for parts if anyone needs one for the low range:)
taza
Post by taza » Thu Mar 22, 2012 12:19 am
guyph_01 wrote:I've got an L series box good for parts if anyone needs one for the low range:)
Ill take it if your giving it away!
d_generate
Post by d_generate » Thu Mar 22, 2012 3:18 am
taza wrote:Ill take it if your giving it away!
BWAHAHAHAHAHAHAHAHA that's Guy, he'll give it to you............for money ;)
Post by TOONGA » Thu Mar 22, 2012 7:19 am
If you have the money scorpion have the gearset
MY_STI
Post by MY_STI » Thu Mar 22, 2012 1:32 pm
Cheers guys, wasn't going to read that thread/tome at work but did anyway...
Appears I only need to lathe the selector ring carrier, already have the other bits modified and ready to go. About time they were used, have been sitting around for years now.
No way can I justify spending coin on Scorpion gear, as much as I'd love to have it.
Plus currently do not have the money, so not an option anyway.
Post by RSR 555 » Thu Mar 22, 2012 4:07 pm
hahahahahahaha.. funny one Taza.. that was a good one mate :-D
MY_STI wrote:Cheers guys, wasn't going to read that thread/tome at work but did anyway...
I would make sure the selector fork slides in and out without interfering.. this is what I noticed on mine.
taza
Post by taza » Thu Mar 22, 2012 4:13 pm
Too bad Guy doesn't give anything away.... :P
