I have been roughing in the electrical wires in a largeish house
Edited with my folding computer thingy
Mmmm thats embarrassing. First time of trying to upload with my phonesteptoe wrote:Be even more interesting if the pictures came through!
Hey - do you need a shiney new Wire EDM or Sink EDM to help your tool room do its stuff ?Silverbullet wrote:Well I might get some strange looks from everyone if I went round the press shop taking photos, but there are 210 ton presses in there dating back to 1956 that are 2 storeys high with a 2M diameter flywheel constantly spinning at a few hundred rpm, along with the newer 300 ton machines that are even bigger! Big enough they have their own ladder and balcony![]()
Only photo I have is of a pile of blocks I had to grind up. It's a tooling and manufacturing company that makes all their own tools and my job at the moment is to use a surface grinder to make all the blocks perfectly square and +/- .005mm in dimensions before they go to be CNC machined into forms, dies, crop blades, punches etc. They use many different kinds of tool steel ranging from not much harder than mild steel to the hardest I've encountered so far, K110 which gets hot after a .02mm cut on the grindertakes ages to grind that stuff since you have to wait for it to cool down every time (the only grinder with coolant is currently too innacurate to use) These 7 particular blocks are M238 and about 150mm x 70 x 50, all had to be absolutely identical.
Thats my Kinda Office !:Dpurp wrote:I work in an office at the moment, which isn't terrible exciting. But here are some very serious pics...
Fun size mars and snickers, wrapped in puff pastry and baked....
