MY windscreen install tips
G'day MY buffs,
I'm about to take on the task of re-fitting Sunnie the Brumby's windscreen with a new rubber - any tips to make it easier and to avoid it leaking?
I've read about it being a dry seal but that you should use some mastic stuff to a) make it easier to install and b) make sure it seals properly.
I've not been able to find anything in the way of a DIY guide on the forum - hoping to pick the brains of those that have done it before.
- littlewhiteute
Well - a rubber seal - no sticky "wet" stuff to deal with...littlewhiteute wrote:Dry fit windscreen, that's a new one.
And can some one please enlighten me about this mastic stuff? Never heard about it before, that's all.
Any specific technique used Jonno? I don't see how silicon spray and a bit of cord does the job... what's the seal fitted to first - the car or the windscreen?
And anyone know where I can get some of the chrome strip stuff from? I damaged some of mine removing the windscreen
O'Briens once sold windscreen sealant in a standard cartridge tube to the public, mastic may be a brand name for ultra sticky black stuff that never sets hard - like what Subaru use on tail light assy to body
My method was not soapy cord, but good idea.
Fit rubber to screen, goop between glass and rubber is optional, tie self a loop of venetian blind style cord around the channel of the screen rubber, bit longer than need, think it was a tweest, just once, squirt mastic goop into channel lay screen onto cars bottom channel all nicely silicone sprayed, start whacking with hel of palm of hand against all to fit up, then get inside, mirror removed helps, pull cord to help ease the rubber inside lip over the screens metal frame. Did mine one person - no witness or advisors
- Silverbullet
I've got all the instructions, cross sections and diagrams, sealant part numbers/codes for doing this in my big Subaru service manual along with every other piece of sealed glass...if I could be bothered to write it all out on here though...Jonno is right with the cord method although the book recommends more than one piece and shows where to lay them (but if Jonno did it by himself then 1 piece obviously works) I think it even tells you what kind of cord and diameter
and you do use sealant.
I'll see if I can scan the pages well enough for you to read and post them here.
That looks like the same stuff as sikaflex... Different name though.TOONGA wrote:mastic
Yep, I used Sikaflex for that job on the tail lights.steptoe wrote:O'Briens once sold windscreen sealant in a standard cartridge tube to the public, mastic may be a brand name for ultra sticky black stuff that never sets hard - like what Subaru use on tail light assy to body
Sweet, this was exactly what I was after! Any more clues on where you had the string poke out from - one end on each A pillar with the ends on the dashboard?steptoe wrote:Fit rubber to screen, goop between glass and rubber is optional, tie self a loop of venetian blind style cord around the channel of the screen rubber, bit longer than need, think it was a tweest, just once, squirt mastic goop into channel lay screen onto cars bottom channel all nicely silicone sprayed, start whacking with hel of palm of hand against all to fit up, then get inside, mirror removed helps, pull cord to help ease the rubber inside lip over the screens metal frame. Did mine one person - no witness or advisors
If you could that would be sweet!Silverbullet wrote:I'll see if I can scan the pages well enough for you to read and post them here.
If only I knew how to youtube back then in 2006.
Think I had string come out inside cabin up top where mirror was, think I had the two directions crossed over each other like first step of tie shoe lace.
Maybe leave rubber in sun with inside face sun to help soften things or fire place, heat gun.
Happened all so quick I can't recall
- Silverbullet
And here's a bit more! a couple of cm's got cut off because I couldn't get it into the scanner (the book is nearly 2 inches thick!) but the useful bit is the sealing compound, it says "Cemedine #366E or Star calking 20G"
Dunno if either of those still exist though
If anyone is interested this book has similar diagrams and cross sections for every other piece of glass for wagon, sedan and hatch.
http://www.mediafire.com/?v5xld6xvdju5ope
Thanks guys! I got the windscreen in with the method that steptoe said - I doubled the rope around the rubber seal and it worked a treat.
I did this after dad told me how he saw the professionals do it years ago - by putting the rubber on the car first then the windscreen in. That wrecked me and the windscreen didn't want to go in at all.
Tried out rubber on the windscreen first then put the two on the car and it went in great.
Now I need to put some sikaflex behind the rubber avoiding the drain holes then work out how to put the chrome strips back in.
And does anyone know where to get that chrome strip stuff from - it looks like it's designed for the specific area it's going into. I damaged one or two pieces when I took them off (a very frustrating exercise!).
The rust paint repair isn't the best job but it'll do for now. I'm keen to get the car resprayed but that's outside our means at the moment and I'm not sure that Gail's keen on it at the moment!
About the Dad thing - It's usually him asking me about subi specific stuff these days
Your way of doing it - probably an hour, I was stuffed after buggering around with the wrong way of doing it! I didn't really time myself, just concentrated on getting it done properly.
Also got a little tip from a mate - line the metal under the rubber with the likes of sikaflex and let it set before installing the windscreen. This will act as a barrier from the water getting to the metal (on top of the paint work). Wish I knew about it before I put the windscreen in!
- Silverbullet
I think there's a special tool for putting them in, I know there is one for getting them out. It's not a special Subaru tool, I think most mobile windscreen guys would have them. On the subject, one of my corner ones just fell out the other night, luckily while I was standing there otherwise it would be long gone
In a safe place now
So here I am a few years down the track trying to jam the windscreen back into Redback. It wasn't going so well and after the third attempt I resorted to the new school method of asking google.
And what came up? This thread! Brought back some memories!
This time I fitted the chrome strips before putting the screen in the vehicle - it all went in well. Some silicone spray helped lube things up - I'm just hoping I haven't weakened th rubber using something like that. Time will tell I guess.
- Willy Fisterbottom
Silicone spray is good as long as you never have to paint the car again.
http://www.willyweather.com.au
