No dash lights and engine does
Joshamc
Post by Joshamc » Sat Oct 13, 2012 11:35 am
Hey I'm new so bare with me. I changed my engine in my 89 brumby. I put in an ea 81 same engine from a wagon. Hooked it all up but I have no dash lights and the car starts but as soon as I release the key off start it dies. I've checked the wiring but can't find anything. Any ideas?
Post by TOONGA » Sat Oct 13, 2012 11:56 am
this sounds like the ignition fuse is blown, Im hoping you know where the fuses are :) if not below the steering wheel on the right hand side, look for the ignition fuse.
If you replace it and it blows again, then you have a positive short somewhere on the engine.
Joshamc
Post by Joshamc » Sat Oct 13, 2012 12:27 pm
Yeah I've checked the fuse no luck. There's no power to the engine fuse I've just realized too.
Post by El_Freddo » Sat Oct 13, 2012 5:00 pm
Check the ignition switch. Sounds like you're getting power to that fuse while in the start position but not when in the on position.
Could be time for a new ignition switch if it doesn't check out correctly.
olddog642
Check out this thread
Post by olddog642 » Sat Oct 13, 2012 10:06 pm
Check out this thread that deals with ignition switch problem and cure
Hylton:twisted::evil:
showthread.php?t=17259&highlight=ignition+switch
Post by steptoe » Sun Oct 14, 2012 8:56 am
you need to find power at coil pos with IGN on position, just before starter motor position. You can cheat for a moment with wire from battery pos to coil pos WITH FUSE in between just in case it blows. Is engine block earthed to body ?
Joshamc
Post by Joshamc » Sun Oct 14, 2012 7:17 pm
Hey thanks all for advice. Turns out it was the ignition barrell. Swapped it over with one I had laying around and works fine.
Post by steptoe » Sun Oct 14, 2012 9:59 pm
Proof of coincidence ? I also changed my ignition switch over thinking I deserved pat on shoulder - got a bite on the arse instead at night in frozen conditions - fusible link in my case was real cause but swap ign over gave immediate improvement before???
