EA81 overflow radiator cap
Hi guys, have been reading the posts regarding fitting an overflow bottle to my EA81 brumby. I have a bottle and hoses set up but was just wondering what sort of radiator cap to use.
I realise it needs to be a return style cap, just after a cap part number or a car model's cap that will fit it properly.
I couldn't find this information in the posts.
Thanks in advance.
P.S. Does anyone know what would cause an EA81 to develop a ticking noise similar to lifter noise when the engine has warmed up? No noise when cold, only when warm.
Thanks in advance.
- scoobymine
- scoobymine
On the EA81 it is not required to have an 'overflow' bottle. The system was designed and built without one, so adding one just creates haedaches. If the sytem is not working correctly then you need to investigate why not.schedango wrote:Hi guys, have been reading the posts regarding fitting an overflow bottle to my EA81 brumby. I have a bottle and hoses set up but was just wondering what sort of radiator cap to use.
The correct cap is the one that suits your year and model of your car. Most aftermarket places will have listings for the correct one.schedango wrote:I realise it needs to be a return style cap, just after a cap part number or a car model's cap that will fit it properly.
Yes.. Oils.. check you are running the correct one for your car.. I'm guessing you'r oil is too thin when warmschedango wrote:P.S. Does anyone know what would cause an EA81 to develop a ticking noise similar to lifter noise when the engine has warmed up? No noise when cold, only when warm.
