Will a GC exhaust fit 99 GT SF5 Forester?
As the title says, niterida is selling one just not sure if it will fit, wondered if anyone knew, tried google but haven't found info yet.
[SIGPIC][/SIGPIC] ..........................................92 Lib 98 Foz 99 GT Foz
I believe you might have to get the tip extended because the rear bumper on a foz is slightly longer
Yep. Can confirm it will fit as long as the GC is from a GC8 and the Foz is a GT turbo
You want me to fit for you? I might be able to fit you in.
- Green_eyed_liberty
Are you sure - the Liberty Wagon exhaust is only 7.5cm longer so I doubt the Forester is 10cm, especially when the Forester is just an Impreza underneath..................Green_eyed_liberty wrote:the WRX exhaust is 10cm shorter than the Forester.
you will also need to modify the rear hangers
If its an NA Forester and Turbo Forrester exhaust - no it wont fit i believe.
im putting my chips on the table.
the rear or tips need to be lengthened by 100mm and rear hangers modified (or running longer exhaust rubbers)
http://www.ozfoz.com.au/forum/viewtopic ... 35176c8e31
my bad. here is a section quoted
[quote="OzFoz.com"]Will a WRX/STI exhaust bolt onto my turbo Forester?
The dump and centre pipes will generally fit fine. Sometimes you may need to fit a new 02 sensor bung and plug the old one depending upon your year model (turbo WRXs and Foresters up to MY00 have the 02 sensor near the turbo]
